07-28-2014, 17:36 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: in heart of innocent peoples Age: 34
Member: 407782 Status: Offline Sonork: 100.1586820 Thanks Meter: 1,052 | n9005 boot repair still can't enter to download mode, ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x00 Application ID : Product Name : 00000 Product Revision : 1.0 Serial Number : 0001E5A7 Manufacture Date: April 2014 Card CID: 0000003030303030100001E5A700E4FB Card CSD: 400E00325B59000077077F800A40001B Card SCR: 02B5000000000000 Card OCR: 00C0FF8000 SD Card Size : 15976103936 Bytes SD Block Size: 512 Bytes Maximum Speed: 25000000 Hertz SDHC / SDXC Card Detected... Checking Lock Status... Micro SD Card is NOT Password Protected!!! Samsung SM-N9005 UNBRICK Start Writing to SDC at 0x00000000... Number of Blocks: 0x00040000 Process Done... ================================================== ==== 1. Insert Micro SD Card to Phone 2. Make Sure Battery is Fully Charged 3. Press Volume Down + Home + Power Button 4. Flash the Phone with ODIN ================================================== ==== Total Elapsed Time 00:02:00 Write Success! |
07-29-2014, 08:32 | #2 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | How file Sdc has used?, Make Video Procedure Not other. 3. Press Volume Down + Home + Power Button No need this step, is a game with power on button and Micro sd, phone vibrate when is in DM or is in good way, Battery FULL Charge, and repeat LOOCK / APPLY VIDEO PROCEDURE, Br allumts |
05-08-2015, 17:10 | #3 (permalink) |
No Life Poster Join Date: Feb 2004 Location: PaKiStAn Age: 44
Member: 51639 Status: Offline Thanks Meter: 76 | only few lucky ones can unbrick their phones with this method i never had success with this method on note 3 or galaxy s4 but only with S3 and note 1, so use other method |
05-09-2015, 12:15 | #4 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
If you use Fake Sd Card, like Not Samsung, San Disk itc... ORIGINAL you Never can have success in restore one easy qualcomm like this BR allumts | |
05-09-2015, 20:42 | #6 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Off Course...but it's not from now.... but since you have can build Sd Card with SDC file with Atf...is NEW for you? ..... Fake Sd Card cannot Never work good becouse phone not see these...togheter of all the rest obvious... More...this is Qualcomm Based and no need any TP...i've restored a couple of these only with Good Sdc File and ORIGINAL Sd Card....all Fake CINA Card "FAILED"...no one in D.Mode... BR |
