01-18-2015, 14:32 | #3 (permalink) |
No Life Poster Join Date: Nov 2009 Location: BaNgLaDeSh Age: 41
Member: 1150957 Status: Offline Thanks Meter: 60 | Detect Phone Connect ... Connect Phone OK. Get PIT for Mapping ... Phone Init Failure ! Total Time: 8.84 s Last edited by brokendreem; 01-18-2015 at 14:37. |
01-19-2015, 14:49 | #4 (permalink) |
Member: 1150957 Status: Offline Thanks Meter: 60 | I found today another phone, problem same need any good solution for this problem help atf support Last edited by brokendreem; 01-19-2015 at 14:55. |
01-23-2015, 14:19 | #6 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @brokendreem, - Start posting here what sdc file (fw version), has used for write in sd card. - What 4 files +Pit you have flashed in this phone?, always you must need of Flash Same version of Sdc file, cannot use any other full flash 4 part file. - If you Fw in Sdc file match with 4 files + Pit, have take out Sd Card before of flash? Answere to this question posting Version of fw used for sdc file + fw used for flash, then post Screenshoot of odin and phone with big immage error. P.d. as i can see you are flashing this device with sd card inside the phone, is true yes? BR allumts |
