03-02-2016, 05:26 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | n9005 connect as HS=USB QDLOADER 9008 I TRIED WITH SDC METHOD ,,NOT RECOVER, NOW HOW TO CONNECT WITH EMMC METHOD,PLZ INFORM, ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x00000000 No ATF Box Found |
03-02-2016, 09:29 | #3 (permalink) |
No Life Poster Join Date: Jan 2010 Location: ANKLESHWAR,GUJARAT,INDIA Age: 41
Member: 1212231 Status: Offline Sonork: 100.1611130 Thanks Meter: 164 | use this pinout http://postimg.org/image/i1g548wb1/ |
03-02-2016, 14:45 | #6 (permalink) |
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | 5 in one,,,,i am using big atf,,plz br,,how to use,,,i make,,all,,wires according to pin out,,and connect with out batery ,,,,,using usb cable,,but not connect |
03-02-2016, 20:58 | #7 (permalink) |
Member: 1212231 Status: Offline Sonork: 100.1611130 Thanks Meter: 164 | 1.8 & 3.3 both on adapter 2.8 if not work so use extra vcc power on adapter 2.8 direct if not work ? post u r adapter pic i will give u best idea |
03-05-2016, 04:35 | #10 (permalink) |
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | But my reseller says,,v2,,all in one is old,,,and atf release ,,,5 in one, better than,,,v2,,,,,,,what to do plz inform,,and confirm,, |
03-05-2016, 04:36 | #11 (permalink) |
