08-01-2015, 20:43 | #2 (permalink) |
Insane Poster Join Date: Mar 2014 Location: Egypt
Member: 2143962 Status: Offline Sonork: 1669485 Thanks Meter: 9 | u just put images explain whats is problem from first to help other people who have same problem if u can share pionts and the files who use it thats will be greatfull bro |
08-02-2015, 06:03 | #3 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Sri Lanka
Member: 815299 Status: Offline Sonork: 100.1623047 Thanks Meter: 133 | Pinout emmc n9005 1 factory erase emmc 2 use org firmware with pit 32 Software takes needed boot file(select all box) 3 select write button After finishing written phone will able to get dwn mode 4 flash with 4files n pit 16 o 33 according to ur phone emmc Than enjoy with working phone again Bro fajeez mashacellular |
The Following 6 Users Say Thank You to Mashacellular For This Useful Post: |
08-15-2015, 13:15 | #7 (permalink) |
No Life Poster Join Date: Oct 2004 Location: AL-SATWA DUBAI U.A.E Age: 45
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | I am Trying to recover dead SM-N9005 by direct emmc but no Luck always this error appear I tried on 3 Phones but same problem Please guide me what to do ? |
08-18-2015, 18:57 | #14 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Not worry bro I Press Thanks Button for those people who do not know the gratitude..also i have all Pinout and all for repair w/o remove EMMC...Next Time NOT post any Clear Pinout or Tip for these peoples.... BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
10-07-2015, 10:16 | #15 (permalink) |
Freak Poster Join Date: Sep 2014 Location: Bahawal Nagar
Member: 2250995 Status: Offline Thanks Meter: 47 | Hv Connected phone in hand .... Confising ur tuturial plz guide step by step 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D4247344743004B035BD2C077 CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 31268536320 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : MBG4GC Product Rev : 0.0 Product SN : 4B035BD2 Manufactured : December 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D4247344743004B035BD2C077.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
