10-07-2015, 13:56 | #16 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
allumts | |
10-07-2015, 14:18 | #17 (permalink) |
Freak Poster Join Date: Sep 2014 Location: Bahawal Nagar
Member: 2250995 Status: Offline Thanks Meter: 47 | How to Use origional firmware ... plz visit sir http://forum.gsmhosting.com/vbb/f609.../#post11332349 how to use origina firmware and pit in ATF EMMC SECETION SIR ... Sm points confusing me |
10-09-2015, 10:00 | #19 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Try Flashing Only PIT for you Device, (go in "imei.info" insert you Imei and Show if you device is 16/32GB), if 32GB use this no other + BL Original .tat.md5 and see if solve BR allumts |
10-09-2015, 10:40 | #20 (permalink) |
Member: 2250995 Status: Offline Thanks Meter: 47 | Only pit flashing ...same error ... Phone is 32GB NT HONK KONG 16 GB Ver did nt unsold emmc connection ...If U think tou write again in ATF emmc section Then i will Fallow Your mentioned steps ... B.R |
10-09-2015, 11:46 | #21 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Read Carefully, i've Not write of FLASH only PIT for you Device, but PIT+BL Original .tar.md5 PIT must need of you EMMC version, if 32GB then use PIT of 32GB, if 16GB....itc.. If you have get in D.MODE from EMMC direct TP, flash of phone goes Done W/O more emmc direct TP, you have just Format+Update FW. Now use Odin as Normal and first Flash 4 file Fw .tar.md5 +PIT if get this PIT error then Flash with ODIN only PIT+BL first. Read above steps in post #16, after step 3 and you phone is in D.Mode: Quote:
BR allumts | |
10-09-2015, 12:12 | #22 (permalink) | |
Member: 2250995 Status: Offline Thanks Meter: 47 | fLASH rEAD fAILOR THERE IS NO PIT BINARY Quote:
1: HLTE_EUR_OPEN.pit 2: BL_N9005XXUFNG2_1955971_REV03_user_low_ship_MULTI_ CERT.tar.md5 Odin hang at write cell screen shows same error there is no pit binary etc | |
10-09-2015, 12:29 | #23 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | NO, Odin Not has Stopped of working in PIT, loock good Screenshoot...is you PC that has STOPPED ODIN....ceck carefully what's the problem in you PC, AV must be Closed when flash and KIES (if have), must need of get in Shut Down....it's not PIT ERROR. Use Other Odin Version like 3.0.7 and Run as Admin. NOTE IMPORTANT: You Must Need of FLASH same Version of BL that have used for Repair EMMC, in this Mode you do other Downgrade and BRICK OTHER TIME this DEVICE. Here Used : BL_N9005XXUFNG2, for Repair have used: N9005XXUGBOA5 what mistake are doing? BR Last edited by allumts; 10-09-2015 at 12:36. |
The Following User Says Thank You to allumts For This Useful Post: |
10-09-2015, 13:28 | #24 (permalink) | |||
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Last time that explain: If you have used this Stock FW .tar.md5 : Quote:
Hope you are undestand clear you error that are Doing, are tryng of Downgrade other Time this Phone if Flash more LOW version. P.D. Pit that i've seen in you Screenshoot, for me isn't been writed from ATF, i've only seen one Big directory and no PIT showing writed. BR | |||
10-09-2015, 13:40 | #25 (permalink) | |
Member: 2250995 Status: Offline Thanks Meter: 47 | BL_N9005XXUGBOA5 Found Quote:
flash with pit but gives me sam eerror ... | |
10-09-2015, 14:45 | #26 (permalink) |
Member: 2250995 Status: Offline Thanks Meter: 47 | Well clearly understand abt my prblem ..... Downlaoding updated bootloader file ...i will creat 4 files from new firmware.... then will post result ..... Sent from my SM-G920F using Tapatalk |
10-10-2015, 22:13 | #27 (permalink) |
Insane Poster Join Date: Mar 2014 Location: Egypt
Member: 2143962 Status: Offline Sonork: 1669485 Thanks Meter: 9 | 1-normal factory ecrease 2-write rom in userarea it show u boxes check all and put pit file 3-make sure if fone 16 or 32 gb to use pite file 4-now u can enter to downlad flash it by 4 files full flash |
11-01-2015, 15:10 | #28 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Quote:
SDC solution not work for me :-( | |
11-01-2015, 15:46 | #29 (permalink) | |
BR allumts | |
11-02-2015, 10:48 | #30 (permalink) |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Ok, Thanks for reply, i read already every thing and now soldering testpoints, please give me firmware for this EMMC ( K3QF7F70EM-QGCE ) |
