04-12-2015, 23:23 | #1 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2378020 Status: Offline Thanks Meter: 0 | n9005 emmc detect error my device is bricked and dead boot i try to repair boot via emmc but i failed and got this error n9005 32gb 00:00:59 : eMMC Test Point Connection Module 00:00:59 : ================================================== ==== 00:00:59 : ================================================== ==== 00:00:59 : 00:00:59 : 1. DO NOT USE THE PHONE"S BATTERY 00:00:59 : 2. Connect the Soldered TP Connections to ATF Box 00:00:59 : 3. Disconnect the USB Cable and Wait until the 00:00:59 : the ATF Software will tell you to Connect the USB. 00:00:59 : 00:00:59 : 00:00:59 : Interface Reset OK! 00:00:59 : eMMC Access Type: SECTOR MODE 00:00:59 : eMMC Supported Voltage Range: 00:00:59 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 00:00:59 : 00:00:59 : CID : 1501004D4247344743001E0EBA0E90CD 00:00:59 : CSD : D02602641EB207FFEDB7FFDF1C80801B 00:00:59 : 00:00:59 : ERROR: EMMC_SEND_EXT_CSD (CMD8) 00:00:59 : Check GREEN Test Point Connection 00:01:40 : eMMC Test Point Connection Module 00:01:40 : ================================================== ==== 00:01:40 : ================================================== ==== 00:01:40 : 00:01:40 : 1. DO NOT USE THE PHONE"S BATTERY 00:01:40 : 2. Connect the Soldered TP Connections to ATF Box 00:01:40 : 3. Disconnect the USB Cable and Wait until the 00:01:40 : the ATF Software will tell you to Connect the USB. 00:01:40 : 00:02:11 : ERROR: EMMC WAS NOT Detected! (CMD1) 00:02:11 : Check your Test Point Soldering! 00:02:11 : CMD1 Reply: 0x00000000 00:02:13 : ================================================== == what is the problem |
04-13-2015, 07:47 | #2 (permalink) | |
Freak Poster Join Date: Dec 2010 Location: Uzbekistan/Jizzakh
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | Quote:
04-14-2015, 14:10 | #3 (permalink) |
Member: 2378020 Status: Offline Thanks Meter: 0 | i got this error R1b Timeout Error! R1b Timeout Error! ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D4247344743001E0EBA0E90CD CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 31268536320 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : MBG4GC Product Rev : 0.0 Product SN : 1E0EBA0E Manufactured : September 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D4247344743001E0EBA0E90CD.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: aboot.mbn Start Writing 0x00000811 Blocks at 0x00026800 Partition Selected: USER AREA R1b Timeout Error! R1b Timeout Error! |
