11-11-2014, 14:50 | #1 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 237816 Status: Offline Thanks Meter: 4 | N9005 Flash Write Failure |
11-12-2014, 10:02 | #3 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
You not are seeing that have flashed with SD CARD in the phone? Sd Card you must need of use ONLY for put phone in D.Mode, after this, get Out sd card and Flash phone with same Fw version of Fw that have in Sd Card. Can flash also only one package Fw, important this match with the same of the sdc file. Also you have a BIG Sticky thread with Video for Unbrick N9005, just watch the video, so not write more Lies about Support of Atf, leave you laziness and move a little you mouse. BR | |
11-12-2014, 14:29 | #4 (permalink) |
Member: 237816 Status: Offline Thanks Meter: 4 | Sorry. I watched and read for many times. But when I put the sd card written on atf and push power button, this screen I attached comes directly. Not the one on video or photos. If someone helps me for one time, I can do next ones. Thanks.. |
11-12-2014, 15:45 | #6 (permalink) |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | hi. whats that 7th line on screen message? whats that 6th line on odin tool? Simple. Ans: is in ........ 4th line in post#3 Try first or Just read ERROR msgs & Google it, or use search button |
The Following User Says Thank You to .::EXTREME::. For This Useful Post: |
11-12-2014, 16:02 | #7 (permalink) | ||
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @skydreas, Stop with you Lies, Quote:
BR | ||
11-12-2014, 16:53 | #9 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hi, All the answers to your questions are in this thread.... I insulting you?...please where i'm insulting you becouse have answered with all details for solve you problem?, no, sorry, if this for you are insulting i not have fault, is only you not knowledge on these things, send in one center for repair.. no more help of this can give you BR allumts |
03-17-2015, 04:13 | #10 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: Jeddah, Saudi Arabia
Member: 1911337 Status: Offline Thanks Meter: 38 | hello Quote:
regards Abdullah Shafique | |
03-17-2015, 19:31 | #11 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Picture of Odin above is FAKE...not to see that "repartition" field in UNsigned but there's PIT file for flash?, is LIAR this man, have add later PIT file. Have flashed device with Sd Card inside the phone and more...will be the same Fw used in Sdc File...but i not think.... Anyway, this is old history, read last version 12.06 and you can see how create by yourself you Sdc File for Sd Card...put in D.Mode and Flash W/O SD CARD the same fw Done...use Sticky thread and read the update from Atf Box. |
