06-18-2012, 21:31 | #1 (permalink) |
No Life Poster Join Date: Mar 2011
Member: 1544019 Status: Offline Thanks Meter: 31 | Whats wrong with this flashing to X5-01??? Code: Number of Image Files: 5 (Mass Memory File Detected) Processing Image File : rm627_043.016_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 418 Entry Point: 0x01F0 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm627_043.016_C24.01_AZURE_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 5 Entry Point: 0x00F5 Page Format : -1 MAX PAGE : 0x00001A00 Processing Image File : Miley_MC011_SD_2G_1.2.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1487 Entry Point: 0x0191 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm627_043.016_33.01_APAC_QW1_prd.rofs2.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 213 Entry Point: 0x00F5 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm627_043.016_U001.000_prd.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 142 Entry Point: 0x00F5 Page Format : -1 MAX PAGE : 0x00040000 AUTO SELECTED DEAD USB FLASHING... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C35 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1F00010E ID DWORD 1 : 849C0344 ID DWORD 2 : 21D186DE ID DWORD 3 : 092C6AD0 ID DWORD 4 : 90D3096F 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0050 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0050 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 20000000 (512 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_XSR17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 352713040481477 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\352713040481477\352713040481477_12933.rpl Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 2154126F0B79D97257DAF5B487C6E429181012F7 ImagePath: C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-627\ ImageFilename: rm627_043.016_prd.core.fpsx Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00020000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 000A0000 Size : 03B20000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 03BC0000 Size : 0ABC0000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 0E780000 Size : 109C0000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 1F140000 Size : 003C0000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF000000040000000300000002000A000003B20000000000040000000203BC00000ABC000000000008000000010E780000109C00000000000A000000011F140000003C000077 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x4F (79) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00020000-0003FFFF 1 : 00060000-004DFFFF 2 : 008E0000-0E77FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000000000002000000640000000B00000002000000010000000000000000 ERASE_REQUEST_BB5 : 5003120B000300000200000003FFFF120B00030000060000004DFFFF120B000300008E00000E77FFFF37 FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000000000002000000640000000B0000000200000001000000000000000033 Successfully Erased... Total blocks to write : 418 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : SOS+PMML >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : LDSP >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ImagePath: C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-627\ ImageFilename: rm627_043.016_C24.01_AZURE_prd.rofs3.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0D100000-0E77FFFF ERASE_REQUEST_BB5 : 5001120B0003000D1000000E77FFFF3E Successfully Erased... Total blocks to write : 5 >> CMT Rootkey Hash CERT : SOS+ROFS3 ImagePath: C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-627\ ImageFilename: Miley_MC011_SD_2G_1.2.fpsx MASS_MEMORY_CONFIG_REQUEST_BB5 : No Error - 0 (0x00) NO ERASE BLOCK FOUND... Total blocks to write : 1487 |
06-19-2012, 10:04 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,590 | Hi, Uncheck this file: Miley_MC011_SD_2G_1.2.fpsx ... and flash phone again. It will be okay. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
06-25-2012, 19:04 | #3 (permalink) |
Member: 1544019 Status: Offline Thanks Meter: 31 | Thank u. Worked. Phone flashed succesfully without problems. Now, Phone power on but its stuck on Nokia logo. As I told, initially phone was come with memory full and phone startup failed problems, but at least was can power on... What can be the problem? |
06-25-2012, 19:14 | #5 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: DUBAI Age: 33
Member: 1189306 Status: Offline Sonork: 100.1589231 Thanks Meter: 273 | Quote:
bro | |
06-25-2012, 19:18 | #7 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | @gsmator Can you get TEST MODE on the phone and Scan Phone? 1. Buscheck Phone to get TEST MODE 2. Go to FORMAT FS Tab and FORMAT all detected DRIVES Post Scan Phone Logs if phone is going into test/local mode. Your FLashing logs also shows some problems... 1. The File sequence is wrong,,, as Mass Memory should be flashed LAST This file: Miley_MC011_SD_2G_1.2.fpsx... So when you got the error,,, that means ROFS2 and UDA was not flashed at all to the phone... Solution: Download again the flash files and make sure you include the VPL file... or Make sure when you manual load the flash files that you put the MASS MEMORY FILE last! and that you have a 2GB SD Card inserted to the SD Card Slot of the phone... Miley_MC011_SD_2G_1.2.fpsx Easiest Solution: Do not flash This file: Miley_MC011_SD_2G_1.2.fpsx... Only flash the other 4 files which you already have... B.R. |
06-25-2012, 19:19 | #8 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,590 | Quote:
It can be hardware problem also.. I'm talking about "startup failed and memory full" ... BR | |
06-25-2012, 19:23 | #9 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,117 | Quote:
Yup,, same problem as those E52s.... 250 degrees Celsius rework + 2.5 centimeters distance from the stacked rapu/onenand in a circular motion and 2.5 minutes should do the trick... However, customer might come back after 2.5 days with the same problem. Sometimes I put 325 degrees Celsius and 3.25 minutes if problem persists | |
The Following User Says Thank You to Advance-Box For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
