Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 07-05-2012, 22:19   #1 (permalink)
MUTUAL's Avatar
Member: 160928
N91 imei 123456 how do i fix it was ok befor [SOLVED]
Hi team i have nokia n91 its was freezing problem, i flash the phone after flash phone showing phone start up fail, so i downgrade the phone and use easy fix option and try to fix downgraded, after that when i scan phone,phone showing like this
             Basic Phone Information
MCU Version: V w33_06w24v4 13-09-06 RM-43 (c) Nokia.
IMEI Plain : 12345610654321?
IMEI Spare : A123456106543210
IMEI SV    : 31234561065432100F
Phone Model: Nokia N91-1
Category   : High End
Phone Type : RM-43
            Extended Phone Information
Product Serial Number: SFF343065
Product Code         : 0535548
Basic Production Code: 0525426
MCU SW Version       : V w33_06w24v4 13-09-06 RM-43 (c) Nokia.
HW Version           : 0600
RFIC Version         : 150a160f
DSP Version          : nemo_w_05wk32v33
AHNE Version         : 22
RETU Version         : 32
TAHVO Version        : 52
Bluetooth ID         : 00:02:5B:00:A5:A5
               Simlock Information
CONFIG KEY    :  0000000000000000
PROVIDER KEY  :  2440700000000000
NETWORK NAME  :  Nokia Default;Finland
LOCK COUNTERS :  KEYPRESS 0/3,  FBUS 0/10
SIMLOCK TABLE :
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE :  Not Locked
SIMLOCK_TYPE             : PA_SL1
SIMLOCK_TEST             : PASSED
SECURITY_TEST     : FAILED
      >  Try SX4 "PM AUTH"
      >  Then Write PM 1 and 309
SECURITY_CODE          : 12345
PHONE_MODE              : LOCAL
Selected VPL File:
RM43_0539382_3.10.023_200.vpl
Variant Details     : EURO 2
Software Version : 3.10.023
Product Type       : RM-43
Product Code      : 0539382
Variant Version    : 200
i already try write pm but still same
The Following 2 Users Say Thank You to MUTUAL For This Useful Post:
Old 07-06-2012, 02:19   #2 (permalink)
Advance-Box's Avatar
Member: 651945
You did not backup RPL before flashing?
It is standard procedure to backup RPL before flashing,
unless you unchecked "Backup RPL" manually...
Also, there are 2 kinds of N91... One is RM-158 and
another is RM-43. If you cross-flashed your phone, then
it is normal to get imei reading of 123456... even if real
imei inside phone is still in tact.
Anyway, try to write you RPL backup first.
If you cannot find your RPL backup file, then
check the LOGS when you clicked "Quick Fix SL1/SL2 Downgrade"
because that one shoul automatically make rpl backup as well.
Old 07-06-2012, 07:04   #3 (permalink)
MUTUAL's Avatar
Member: 160928
i try the back up file still same can i buy rpl?
The Following User Says Thank You to MUTUAL For This Useful Post:
Old 07-06-2012, 07:52   #4 (permalink)
Member: 651945
@MUTUAL
Upload here your Backup RPL File... And I will check it.
in my previous post, this is very important that you understand it:
I am saying simply that you maybe flashed your NON 8GB N91 with an
8GB flash file or vice versa...
Better check the back sticker of the phone if it is really RM-43
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 07-06-2012, 08:35   #5 (permalink)
AOA
AOA's Avatar
Member: 1166923
Flash your phone by Product Code : 0535548. maybe can solve your problem
Old 07-06-2012, 17:38   #6 (permalink)
asad_nomy7's Avatar
Member: 570093
Its problem with versions.flash with ur product code or try to downgrade with lower version ur problem will be solved.
2.10.013
2.20.008
The Following 2 Users Say Thank You to asad_nomy7 For This Useful Post:
Old 07-08-2012, 21:25   #7 (permalink)
MUTUAL's Avatar
Member: 160928
@MUTUAL
here is rpl back up i had problem befor with new version ATF Booting Phone via FBUS... so when ever i have to flash i have to un tick back up rpl any way after u guys fix the problem with is great here my back up plz let me know what should i do?
i already flash the phone with same product code stil no joy
Old 07-09-2012, 05:27   #8 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Where is your Backup ????
Br - srinibas
Old 07-09-2012, 05:50   #9 (permalink)
MUTUAL's Avatar
Member: 160928
Br - srinibas
358391001075119_90623.rpl
Old 07-09-2012, 08:31   #10 (permalink)
AOA
AOA's Avatar
Member: 1166923
Serial number : 358391001075119
Country : AUSTRALIA
Old 07-09-2012, 09:51   #11 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
PAPUBKEYS: B2E0D53F2FDDF1FC8E55510130F0D06771352435
Asic Public ID: 233001030A744E512B0A58D98A167969D5C7A1BE
IMEI plain in RPL : 35839100107511
Product code in rpl: 0535548
RPL backup OK , so what problem you facing ?
Contact me to check through Team Viewer
Br - srinibas
Old 07-09-2012, 21:30   #12 (permalink)
MUTUAL's Avatar
Member: 160928
Br - srinibas
my problem is showing phone start up fail
ok can u add me on yahoo plz my id is salim_namazi@yahoo.com
u can check it out thru team viewer
thanks for ur help
Old 07-10-2012, 09:08   #13 (permalink)
asad_nomy7's Avatar
Member: 570093
@Mutual which model u select in Model Tab because there r 2 N91 RM-43.u have n91-1 rm 43.one time i wrongly select 5130c-2 rm-495 then my imei also shown 123.so check it plz.
Old 07-10-2012, 11:21   #14 (permalink)
.:TithiMobile:.'s Avatar
Member: 629327
Sonork: 100.1615688
downgrade with 2.10.13 version with same product code
i had same problem before and 100% tested by me
Old 07-10-2012, 21:02   #15 (permalink)
MUTUAL's Avatar
Member: 160928
i selected right model
i already try this no luck
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 12-10-2012 04:46
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 11-21-2011 00:44
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-16-1999 08:41
Page generated in 1.21172 seconds with 11 queries
