06-05-2016, 13:14 | #2 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Read always STICKY Thread. You phone is Exinos based phone, so can try with this procedure, Of Course you nust need Last version of "Bootloader". http://forum.gsmhosting.com/vbb/f609...oader-1885507/ If no success post here what file have used for create Sdc Card. In Exinos phone can also use TP, (CMD) point shorting and Sdc file right. BR allumts |
The Following 2 Users Say Thank You to allumts For This Useful Post: |
06-05-2016, 13:47 | #3 (permalink) | |
Freak Poster Join Date: Apr 2016 Location: azaz
Member: 2560889 Status: Offline Thanks Meter: 106 | Quote:
thanks | |
06-05-2016, 13:58 | #4 (permalink) |
Member: 2560889 Status: Offline Thanks Meter: 106 | i have 6.0.1 rom but it is one file rom, can i create sdc file from this rom because i do not know which version was installed on phone and the last version is 6.0.1 |
06-05-2016, 14:10 | #5 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Yes you can create Sdc File also with Stock Fw now (PDA field), and Right PIT for you device, then create Sd Card. File must be in .tar.md5 Original from Sammobile. |
The Following User Says Thank You to allumts For This Useful Post: |
06-05-2016, 14:18 | #6 (permalink) | |
*select pda file( that i have earlier with ver 6.0.1) *then select pit file *now press creat sdc file *copy created file to sd card *put sd card in phone and phone must enter download mode ( with jig ) | |
The Following User Says Thank You to Zakaria Shekhoo For This Useful Post: |
06-06-2016, 13:40 | #8 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, now Stop here and Read STICKY THREADS. You aren't any Special user, so if not are good to find TP (CMD) point in the web, google itc... Find by yourself, last time i Pit in you handles all, here: http://forum.gsmhosting.com/vbb/f609...orial-1908984/ Atf Support put in your handles all for find all solution Alone, if not Use isn't Fault of Atf Support only you Fault. Here have all in handles, if not are good, send this phone to one Good Shoop of repair, Br |
06-06-2016, 14:07 | #9 (permalink) |
Member: 2560889 Status: Offline Thanks Meter: 106 | ok thanks for your reply finally just i want to know which test points i have to find to solder togother thanks again and i am sorry to annoy you, but this is the first phone to fix ( i purchased ATF two weeks ago ) |
06-07-2016, 09:19 | #11 (permalink) |
Major Poster Join Date: Jan 2009
Member: 936228 Status: Offline Thanks Meter: 4 | brother allumts i have the same problem N910H dead i tried to create sdc file and success with atf box, but box tell me that i must solder A and B points, and here is my problem, what is the two points ?? is it clk,cmd,nc,datao,gnd or ... which of them ??? thanks in advance brother |
06-07-2016, 09:34 | #12 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Instead of write Useless post, why not open you eyes and read only above where there are 6/7 post with explained CLEAR and marked what iis the point? Not touch you phone if not unterstand wich Resistor is also Good showed above 7 times, send you phone in Goos Shop for repair, listen to me. Br |
06-07-2016, 09:38 | #13 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Anyway, in above Post there are all mode for find all pinout you want just read link and apply. Br | |
06-07-2016, 11:14 | #15 (permalink) | |
For other, you will have all in you handles and already?, and explai why 1000 other user not will have this Privilege? Have full Procedure explained very clear, if want find Full pinout can found by yourself no need of nobody, just apply procedure of above link, if want repair fast and speed, otherwise remain here waiting how a LOT of other that no want do any effort. At last, phone damaged is you phone, and for gain money a small of effort must need, to much easy post request and other, (like me for example), to put to work for you....Remember that all my Help i have given here have done from my heart, at last this isn't my section of Supporter, so to be greatfull for my help given and all link and tips. BR | |
