02-21-2010, 10:20 | #1 (permalink) |
No Life Poster Join Date: Sep 2003 Location: WATCHING YOU
Member: 38562 Status: Offline Thanks Meter: 1,478 | N97 FULL FLASH VIA FBUS 1min and 34secs Code: AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Init TRY : 2 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : A780076AC67CF8B89D23276C BOX ACTIVATED DDR DELAY : 01 INIT : OK Changing MODE : FLASH Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-505\RM-505_12.0.026_prd.core.C00 CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 0003192101002003 > 000C192101002003 > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 > 4003192101051103 > 400C192101051103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 420 Entry Point: 0x292C10 Page Format : -1 MAX PAGE : 0x00040000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 4677748 (0x74) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01031103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0EC0010C ID DWORD 1 : A4DA0158 ID DWORD 2 : C9A41A96 ID DWORD 3 : F4F52613 ID DWORD 4 : 7B33753D 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 74 BootCodeLen : 61 SearchForBootstrap_DCT5.. Boot File MATCH : RAPIDOv11_2nd.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 BB5ProtocolType == : New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 Checksum : 15 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Algo File MATCH : RAPIDOv11_XSR15_alg.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 ALGO FILE : C:\AdvanceBox Software 2\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) VPP Enabled by Software Using Internal VPP VPPSwitchInfo : VPP1 VPP_GENERATED_IN_PROMMER - VPP2 VPP_GENERATED_IN_PROMMER CMT Does Not Support 12V VPP CMT Does Not Support Group Erase VPP Enabled by Software 00 unsupported VPP Voltage setting Using Internal VPP SendFlashVoltageInit_DCT5 VPP1 0000 VPP2 0000 FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... PART LEN : 0052 Partition Info Partition Blocks : 1 PART ID : 2F , blklen : 4F 1 PARTITION_INFO_BB5 check nko asic : 0 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 019A0000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 019A0000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 019A0000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00080000 Size : 019A0000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000000200080000019A0000000000040000000201A200000918000000000008000000010ABA000004B800000000000A000000010F8C000000160000C5 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x0057 (87) ERASE Blocks : 0x0002 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-00082FFF 1 : 00083400-003FFFFF 2 : 00800000-00D5FFFF 3 : 00D60000-0AB9FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID :0x00000000 Format Info :000000000000000A000000000000000200000064000000030000000100000001000000000000 ERASE_REQUEST_BB5 : 5004120B0003000004000000082FFF120B00030000083400003FFFFF120B0003000080000000D5FFFF120B00030000D600000AB9FFFFDE Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 ERASE_REQUEST_BB5 : 5001192F00030000000000000000000000000A0000000000000002000000640000000300000001000000010000000000003E Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. Is Flashing CLOCK AUTO : -1 Processing : RM-505_12.0.026_prd.core.C00 Total blocks to write : 420 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:55 Making delay between files for 7000ms Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-505\RM-505_12.0.026_prd.rofs2.V26 CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 0003192101002003 > 000C192101002003 > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 > 4003192101051103 > 400C192101051103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 134 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 4677748 (0x74) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01031103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0EC0010C ID DWORD 1 : A4DA0158 ID DWORD 2 : C9A41A96 ID DWORD 3 : F4F52613 ID DWORD 4 : 7B33753D 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 74 BootCodeLen : 61 SearchForBootstrap_DCT5.. Boot File MATCH : RAPIDOv11_2nd.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 BB5ProtocolType == : New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 Checksum : 15 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Algo File MATCH : RAPIDOv11_XSR15_alg.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 ALGO FILE : C:\AdvanceBox Software 2\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) VPP Enabled by Software Using Internal VPP VPPSwitchInfo : VPP1 VPP_GENERATED_IN_PROMMER - VPP2 VPP_GENERATED_IN_PROMMER CMT Does Not Support 12V VPP CMT Does Not Support Group Erase VPP Enabled by Software 00 unsupported VPP Voltage setting Using Internal VPP SendFlashVoltageInit_DCT5 VPP1 0000 VPP2 0000 FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE No partition info.... StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 06EA0000-09C9FFFF ERASE_REQUEST_BB5 : 5001120B00030006EA000009C9FFFF1E Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. Is Flashing CLOCK AUTO : -1 Processing : RM-505_12.0.026_prd.rofs2.V26 Total blocks to write : 134 >> CMT Rootkey Hash CERT : SOS+ROFS2 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:20 Making delay between files for 7000ms Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-505\RM-505_12.0.026_C01_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 0003192101002003 > 000C192101002003 > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 > 4003192101051103 > 400C192101051103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 6 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00000E00 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 4677748 (0x74) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01031103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0EC0010C ID DWORD 1 : A4DA0158 ID DWORD 2 : C9A41A96 ID DWORD 3 : F4F52613 ID DWORD 4 : 7B33753D 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 74 BootCodeLen : 61 SearchForBootstrap_DCT5.. Boot File MATCH : RAPIDOv11_2nd.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 BB5ProtocolType == : New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 Checksum : 15 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Algo File MATCH : RAPIDOv11_XSR15_alg.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 ALGO FILE : C:\AdvanceBox Software 2\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) VPP Enabled by Software Using Internal VPP VPPSwitchInfo : VPP1 VPP_GENERATED_IN_PROMMER - VPP2 VPP_GENERATED_IN_PROMMER CMT Does Not Support 12V VPP CMT Does Not Support Group Erase VPP Enabled by Software 00 unsupported VPP Voltage setting Using Internal VPP SendFlashVoltageInit_DCT5 VPP1 0000 VPP2 0000 FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE No partition info.... StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 09CA0000-0AB9FFFF ERASE_REQUEST_BB5 : 5001120B00030009CA00000AB9FFFF4A Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. Is Flashing CLOCK AUTO : -1 Processing : RM-505_12.0.026_C01_prd.rofs3.fpsx Total blocks to write : 6 >> CMT Rootkey Hash CERT : SOS+ROFS3 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:00 Making delay between files for 7000ms Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-505\RM505_507_12.0.026_uda7_001.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 0003192101002003 > 000C192101002003 > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 > 4003192101051103 > 400C192101051103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 89 Entry Point: 0x00F9 Page Format : -1 MAX PAGE : 0x00040000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 4677748 (0x74) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01031103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0EC0010C ID DWORD 1 : A4DA0158 ID DWORD 2 : C9A41A96 ID DWORD 3 : F4F52613 ID DWORD 4 : 7B33753D 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 74 BootCodeLen : 61 SearchForBootstrap_DCT5.. Boot File MATCH : RAPIDOv11_2nd.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 BB5ProtocolType == : New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 Checksum : 15 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Algo File MATCH : RAPIDOv11_XSR15_alg.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 ALGO FILE : C:\AdvanceBox Software 2\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) VPP Enabled by Software Using Internal VPP VPPSwitchInfo : VPP1 VPP_GENERATED_IN_PROMMER - VPP2 VPP_GENERATED_IN_PROMMER CMT Does Not Support 12V VPP CMT Does Not Support Group Erase VPP Enabled by Software 00 unsupported VPP Voltage setting Using Internal VPP SendFlashVoltageInit_DCT5 VPP1 0000 VPP2 0000 FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE No partition info.... StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0ABA0000-0F71FFFF ERASE_REQUEST_BB5 : 5001120B0003000ABA00000F71FFFF9C Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. Is Flashing CLOCK AUTO : -1 Processing : RM505_507_12.0.026_uda7_001.uda.fpsx Total blocks to write : 89 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:14 Making delay between files for 7000ms CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 0003192101002003 > 000C192101002003 > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 > 4003192101051103 > 400C192101051103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 16 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 4677748 (0x74) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01031103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0EC0010C ID DWORD 1 : A4DA0158 ID DWORD 2 : C9A41A96 ID DWORD 3 : F4F52613 ID DWORD 4 : 7B33753D 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 74 BootCodeLen : 61 SearchForBootstrap_DCT5.. Boot File MATCH : RAPIDOv11_2nd.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 BB5ProtocolType == : New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 Checksum : 15 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Algo File MATCH : RAPIDOv11_XSR15_alg.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 ALGO FILE : C:\AdvanceBox Software 2\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) VPP Enabled by Software Using Internal VPP VPPSwitchInfo : VPP1 VPP_GENERATED_IN_PROMMER - VPP2 VPP_GENERATED_IN_PROMMER CMT Does Not Support 12V VPP CMT Does Not Support Group Erase VPP Enabled by Software 00 unsupported VPP Voltage setting Using Internal VPP SendFlashVoltageInit_DCT5 VPP1 0000 VPP2 0000 FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE No partition info.... StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00400000-007FFFFF ERASE_REQUEST_BB5 : 5001120B00030000400000007FFFFF21 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. Is Flashing CLOCK AUTO : -1 Processing : rm505ENOA09w23v0.010.fpsx Total blocks to write : 16 >> CMT Rootkey Hash CERT : SOS*ENO ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:02 Making delay between files for 7000ms Total Flashing Time (Excluding ERASE Times) : 00:01:34 Rebooting Box ... AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : A780076AC67CF8B89D23276C BOX ACTIVATED DDR DELAY : 01 INIT : OK Changing MODE : UART Reading Phone Information... MCU: V ICPR72_09w17.7 24-08-09 RM-505 (c) Nokia IMEI: 354225031729861 Simlock Version : SIMLOCK SERVER CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked Lemor Last edited by lemor; 02-21-2010 at 17:23. |
The Following 10 Users Say Thank You to lemor For This Useful Post: |
E52 FULL Flash via FBUS = 49 Seconds | Advance-Box | Advance-Box | 24 | 04-07-2010 11:26 |
E63 FULL FLASH VIA FBUS = 1min 31SECS | lemor | Advance-Box | 6 | 02-19-2010 11:17 |
