ERROR: ROOT Access Failed!
Advance Turbo Flasher Found
Driver Version : 00020824
Library Version : 00030207
Box Type : ATF Nitro
Box Firmware : LogiCore 11.0.10
Software Version : v12.40
AdvanceBox SN : 9D9DE65AD5B9BF6FEF4D3316
Box Status : ACTIVATED
Box Successfully Initialized
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Enable USB debugging on your Phone
Go to Settings -> About phone,
and tap 5 times "Model",
then tap 5 times "Software version",
then go to Settings -> Developer Options
and Enable USB debugging
Nokia X/X+/XL/XL4G/X2 Factory Programming
Power On the Phone and Connect it to the USB Port
USB Debugging MUST BE Enabled in Developer Options
SW Version : 2.1.0.13
IMEI #2 Plain : 353646060518613
IMEI #1 Plain : 353646060518605
Phone Model : NokiaX2DS
Phone Type : RM-1013
Serial Number : dc35c8d1
Extended Phone Information
Build Description : ara-user 4.3 JLS36C 491 release-keys
Build Fingerprint : Nokia/RM-1013/RM-1013:4.3/JLS36C/491:user/release-keys
Android OS Version : 4.3
Product Platform : Nokia X software platform 2.1
Remounting System...
Rebooting Device...
Please Wait for Phone to Finish Booting...
Entering Programming Mode...
Make Sure to Install Correct Drivers from
C:\AdvanceBox Turbo Flasher\Driver\NOKIA_ANDROID_FACTORY\
and
C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X_USB_DRIVERS\
Operation Cancelled...
Shutting Down ADB Server...
If your Phone is still not detected by
ATF Software, manually End Process adb.exe
in Windows Task Manager...
Process Cancelled...
Rebooting Device...
and
Rebooting Device...
and
ERROR: Please Select the Correct Phone Type!
ERROR: System Remount Failed!
Rebooting Device...
and
