03-31-2014, 09:33 | #1 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 969318 Status: Offline Thanks Meter: 82 | Need drivers for lumia 920? It's windows phone 8. |
04-01-2014, 08:14 | #3 (permalink) |
Freak Poster Join Date: Jul 2009 Age: 34
Member: 1078009 Status: Offline Thanks Meter: 12 | I assume you're using Windows 8 on your PC? Try uninstalling all driver packages and ATF completely AND remove the "Advance Turbo Flasher" folder on your C-drive. Reboot your PC and try installing it again. For me, Windows 8 found every driver itself. Also try different USB Port. Hope it helps |
04-01-2014, 08:14 | #4 (permalink) |
04-01-2014, 09:37 | #6 (permalink) |
Member: 1078009 Status: Offline Thanks Meter: 12 | Oh, i thought it was a missspelling above I guess it's not necessary to explain, that a lumia 920 is a windows phone 8 device Ok, i would try to unsinstall and re-install everything as mentioned above. After installing the driver package, try to force driver intallation in windows device manager. Maybe this works If not: try a pc with at least windows 7. |
04-01-2014, 12:36 | #8 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @big_gsm 1. Install: C:\AdvanceBox Turbo Flasher\Driver\WinUSB\ 2. C:\AdvanceBox Turbo Flasher\Driver\Nokia_Connectivity_Cable_Driver_7.1 .182.0.msi Connect Phone to USB in Normal Mode. You will see message: Found New Hardware Wizard: RM-821!Nokia Lumia 920 Click Cancel at first to this message, on next, Click Next and and give this PATH: C:\AdvanceBox Turbo Flasher\Driver\Lumia and Asha Phone Drivers It will install the drivers: Nokia USB Connectivity; then you can Sacn Phone in ATF Software. BR |
