07-19-2012, 07:50 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Pakistan fr city kohat
Member: 1213187 Status: Offline Sonork: 1612770 g.raziq Thanks Meter: 157 | ATF team ATF Box is not in USB 2.0 Mode ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ************************************************ INIT : FAILED , CHECK YOUR BOX FIRMWARE ************************************************ plz needed hlep meee on raziqbbr |
07-19-2012, 09:05 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | @ raziqbbr if you followed the Instruction given by ATF & it not worked then it may b a hardware problem . Post your box type for next Br - srinibas |
many thanks to fast unloking team | rawhi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-26-2002 13:27 |
WinDLS by CODEC TEAM-ROMANIA | dedekwien | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-23-2002 15:33 |
hackertronics.com=FreeGSM team????? | robinhood | The Market Feed Back | 13 | 08-14-2001 20:17 |
_sHARe_dA sTuFF - mobile.box.sk -HQ releases from Royalgsm and RADiANCE TEAM | mr_johnson | GSM Mobile Links | 1 | 05-19-2001 22:29 |
NEW NEW X-treme Gsm Team | Salami1_1 | GSM Mobile Links | 0 | 04-13-2001 13:57 |
