04-28-2014, 17:01 | #1 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 702472 Status: Offline Thanks Meter: 18 | need help I trying to revive one note 3 but alway sd card enought problem i use 8gb scan disk ================================================== ==== ================================================== ==== Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x00 Application ID : Product Name : Product Revision : 0.0 Serial Number : 00000000 Manufacture Date: January 2000 Card CID: 00000000000000000000000000000000 Card CSD: 00000000000000000000000000000000 Card SCR: 0000000000000000 Card OCR: 0000000000 SD Card Size : 8 Bytes SD Block Size: 2 Bytes Maximum Speed: 100000 Hertz Checking Lock Status... Micro SD Card is NOT Password Protected!!! ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== Card Reset Done! Initializing Micro SD Card... Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0xFF Application ID : ÿÿ Product Name : ÃÀà Product Revision : 0.0 Serial Number : 00000000 Manufacture Date: January 2000 Card CID: FFFFFFC3C0E010000000000000000000 Card CSD: FFFFFF1B838040000000000000000000 Card SCR: FFFFFF87C0C00000 Card OCR: 0100780000 SD Card Size : 524288 Bytes SD Block Size: 2 Bytes Maximum Speed: 130000000 Hertz Checking Lock Status... Micro SD Card is NOT Password Protected!!! ================================================== ==== ERROR: SDC Total Size is Not Enough! Insert an SD Card with a Larger Capacity ================================================== ==== Total Elapsed Time 00:00:04 ERROR: WRITE FAILED! |
04-29-2014, 07:41 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | ERROR: SDC Total Size is Not Enough! Insert an SD Card with a Larger Capacity Use 16 gb or 32 gb & post result Br - srinibas |
04-29-2014, 09:57 | #3 (permalink) |
Member: 702472 Status: Offline Thanks Meter: 18 | 16 g try same error Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x00 Application ID : Product Name : Product Revision : 0.0 Serial Number : 00000000 Manufacture Date: January 2000 Card CID: 00000000000000000000000000000000 Card CSD: 00000000000000000000000000000000 Card SCR: 0000000000000000 Card OCR: 0000000000 SD Card Size : 8 Bytes SD Block Size: 2 Bytes Maximum Speed: 100000 Hertz Checking Lock Status... Micro SD Card is NOT Password Protected!!! ================================================== ==== ERROR: SDC Total Size is Not Enough! Insert an SD Card with a Larger Capacity ================================================== ==== Total Elapsed Time 00:00:39 ERROR: WRITE FAILED! |
04-29-2014, 14:33 | #4 (permalink) |
Member: 702472 Status: Offline Thanks Meter: 18 | Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x04 Application ID : A Product Name : SMISD Product Revision : 0.0 Serial Number : 00000000 Manufacture Date: September 2011 Card CID: 041641534D495344000000000000B96F Card CSD: 00000000000000000000000000000000 Card SCR: 0000000000000000 Card OCR: 00C0FF8000 SD Card Size : 8 Bytes SD Block Size: 2 Bytes Maximum Speed: 100000 Hertz SDHC / SDXC Card Detected... Checking Lock Status... Micro SD Card is NOT Password Protected!!! ================================================== ==== ERROR: SDC Total Size is Not Enough! Insert an SD Card with a Larger Capacity ================================================== ==== Total Elapsed Time 00:00:04 ERROR: WRITE FAILED! sa same error with 32g now |
