12-17-2012, 19:43 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: i dont know. where i am Age: 35
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | need help about sl3 simlock recovery then i am submit it for repair simlock ,after submit srp file showing pls check atf support site after 24 hours for your status , @but 30+ hours gone ,still idont get any result @confrimly i dont know from which support site i have to check for status @ also i dont know sl3 simlock recovery way by atf its my first phone,so no have better idea about atf simlock recovery service @still 25 srp credit showing . so i need proper help from atf support site hope i will get reply shortly and will be solved this issue |
12-18-2012, 07:53 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Post the recovery LOG Here the tutorial how to upload job - http://forum.gsmhosting.com/vbb/f609...-only-1523680/ Br - srinibas |
12-18-2012, 09:31 | #4 (permalink) |
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | OK ,Finally i did it ,but still showing 25 srp credit ,but now submit srp option is disable .maybe i have to buy another 25 credit then this option will be enable again .i dont know i am right or not ? normally how long take time for repair simlock ? and what is the way for unlock sl3 by atf ?i have 20 sl3 credit .how many ps set i can unlock ? |
12-18-2012, 09:31 | #5 (permalink) |
12-19-2012, 18:41 | #8 (permalink) | |
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | Quote:
ok can u give me another idia ? how can i know which sl3 phone i can repair simlock free without 25 srp credit ?because one srp file read need time 2 hours .so i want to check before read dump pattion | |
12-20-2012, 07:54 | #9 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
possible for you to backup the IMEI via a Backup RPL Function. There was no way for you to backup a possibly 100% working SIMLOCK inside the phone because you needed Local/Test Mode in order to get the PM Backups. Dead Phones cannot give you Local/Test Mode at all, so you cannot backup the Simlocks even if you wanted to. Now here comes the Solution... The ATF Simlock Recovery Module v1.0 will allow you to BACKUP SIMLOCKS from a DEAD PHONE! Just a 1-click solution for Recovery Level 1 and Level 2 for NON-CORRUPTED SIMLOCKS on a DEAD PHONE. Even if your phone SIMLOCKS are CORRUPTED, The ATF Network can still attempt to perform a Level 3 Recovery from it, but it will cost you some ATF SL3 Credits. Here is a Short Description about the three Simlock Recovery Levels: Recovery Level 1 * FREE for ALL ATF BOX Users (DOES NOT NEED CREDITS or ATF NETWORK ACTIVATION) * Phone DOES NOT need to be AUthorized * 100% Stand Alone * Supports ALL SL3 XSR3 NAND Blocks for RAPUv1, RAPUv2, RAPIDO, RAPG3v4 and BCM21351 * Supports ALL SL3 XSR2 NAND Blocks for RAPUv1, RAPUv2, RAPIDO, RAPG3v4 and BCM21351 * Supports ALL SL3 NOR Blocks for RAP3Gv3 (FULL PM RECOVERY) * Supports ALL SL2 NOR Blocks for RAP3Gv3 (FULL PM RECOVERY) * Supports ALL SL1 NOR Blocks for RAP3Gv3 (FULL PM RECOVERY) * Supports USB or FBUS Connection (FBUS ONLY FOR RAP3Gv3) * Recover from DUMP FILE or from Connected PHONE * Super Fast Recovery, BUT SIMLOCKS WILL NOT BE VERIFIED * The output file is a REGULAR PM FILE with PM 120 Sections 0, 1, 2 and 3 * DOES NOT SUPPORT FULLY ERASED PHONES * SUCCESS RATE = 70% if the CORRECT SIMLOCKS ARE STILL INSIDE THE FLASH DUMP Recovery Level 2 * FREE for ALL ATF Network Users (DOES NOT NEED CREDITS) * Phone NEEDS to be Authorized via The ATF Network * Stand Alone ONLY AFTER PHONE IS AUTHORIZED via The ATF Network * Supports ALL SL3 XSR3 NAND Blocks for RAPUv1, RAPUv2, RAPIDO, RAPG3v4 and BCM21351 * Supports ALL SL3 XSR2 NAND Blocks for RAPUv1, RAPUv2, RAPIDO, RAPG3v4 and BCM21351 * Supports ALL SL3 NOR Blocks for RAP3Gv3 (FULL PM RECOVERY + RECOVER ORIGINAL SIMLOCKS if SIMLOCKS are OVERWRITTEN) * Supports ALL SL2 NOR Blocks for RAP3Gv3 (FULL PM RECOVERY) * Supports ALL SL1 NOR Blocks for RAP3Gv3 (FULL PM RECOVERY) * Supports USB or FBUS Connection (FBUS ONLY FOR RAP3Gv3) * Recover from Connected PHONE ONLY * Recovery Time will depend on Fragmentation Level of the XSR Blocks * SIMLOCKS WILL BE VERIFIED (Since Phone is already Authorized) * The output file is a REGULAR PM FILE with PM 120 Sections 0, 1, 2 and 3 * DOES NOT SUPPORT FULLY ERASED PHONES * SUCCESS RATE = 95% if the CORRECT SIMLOCKS ARE STILL INSIDE THE FLASH DUMP Recovery Level 3 * Needs SL3 Credits and only available for ATF Network Activated Users * Phone NEEDS to be Authorized via The ATF Network * Recovery is performed by our Servers (NOT STAND ALONE) * Supports ALL SL3 XSR3 NAND Blocks for RAPUv1, RAPUv2, RAPIDO, RAPG3v4 and BCM * Supports ALL SL3 XSR2 NAND Blocks for RAPUv1, RAPUv2, RAPIDO, RAPG3v4 and BCM * Supports ALL SL3 NOR Blocks for RAP3Gv3 * Supports USB or FBUS Connection (FBUS ONLY FOR RAP3Gv3) * Recovery Time will depend on CURRENT TASK LOAD on the ATF Simlock Recovery Server * SIMLOCKS WILL BE VERIFIED (Since Phone is already Authorized) * The output file is a REGULAR PM FILE with PM 120 Sections 0, 1, 2 and 3 * POSSIBLE TO SUPPORT OVERWRITTEN PM 120 Blocks with Wrong PM 120 Blocks * POSSIBLE TO SUPPORT FULLY ERASED PHONES * DOES NOT SUPPORT WRONG FLASHED PHONES with WRONG FIRMWARE (Repartitioned NANDs) * SUCCESS RATE = 95% if the Phone is not wrongly Repartitioned by a wrong Firmware | |
