06-24-2012, 06:52 | #1 (permalink) |
No Life Poster Join Date: Jun 2010 Location: việt nam
Member: 1327392 Status: Offline Thanks Meter: 405 | need help ATF DRIVERS error - [SOLVED] I need help from the ATF Thank * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ****************************************** **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ************************************************ INIT : FAILED , CHECK YOUR BOX FIRMWARE ************************************************ |
06-24-2012, 07:40 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Follow the instruction of 3rd picture by ATF If still problem contact me on messenger Br - srinibas ( ATF Team ) |
The Following User Says Thank You to srinibas For This Useful Post: |
06-24-2012, 09:21 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | @students Do you have pop up message in Windows XP telling you that you have connected a USB 2.0 device into a non USB 2.0 Port ? If you are 100% sure you do not see any pop up message on the lower right corner above the TIME of your desktop, then all you need to do is to make a RESTORE BOX. Product Support ---> Box Tools ---> Restore Box Btw, select correct box type before Restoring |
The Following User Says Thank You to Advance-Box For This Useful Post: |
06-24-2012, 13:25 | #4 (permalink) | |
Member: 1327392 Status: Offline Thanks Meter: 405 | Quote:
Product Support ---> Box Tools ---> Restore Box Advance-Box Secure AES-128 Channel Open Port Success... Error return code 6 Error return code Elapsed time = 00:00:00 I need help ATF DRIVERS error I need help remote TeamViewer from the ATF team me time help from the ATF team students Send Message ID and password Thank Last edited by students; 06-24-2012 at 13:30. | |
06-24-2012, 14:07 | #5 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: DUBAI Age: 33
Member: 1189306 Status: Offline Sonork: 100.1589231 Thanks Meter: 273 | Quote:
bro | |
The Following User Says Thank You to gsm_new1 For This Useful Post: |
06-29-2012, 03:31 | #9 (permalink) |
Member: 1327392 Status: Offline Thanks Meter: 405 | students tried installing but still not use the box The cable connect PC Change 3 cable Change 4 pc but still not use the box ATF team someone can help students Thanks |
12-01-2012, 11:34 | #13 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1430565 Status: Offline Thanks Meter: 0 | smae problem for my atf please help Error return code 6 while restoring Advance-Box Secure AES-128 Channel Open Port Success... Error return code 6 Error return code Elapsed time = 00:00:00 |
12-01-2012, 11:54 | #14 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | @tawheeddon If you do not have other boxes connected on the USB Port then most probably the Solution is HARDWARE BASED... Open ATF Box and check the LEGS of the 2 BIG IC CHIPS on the PCB.. After you make sure that ALL the LEGS of the CHIPS are soldered to the PCB, then your problem will be solved. B.R. |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
