10-02-2012, 17:32 | #1 (permalink) |
Registered User Join Date: Mar 2008 Location: karachi
Member: 726546 Status: Offline Sonork: 100.1578784 Thanks Meter: 555 | need help from atf team - [SOLVED] driver is perfectly installed already all folow all steps but still unable to use atf on my pc * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers now plz guide mee how to solve my prob i did fresh window also |
10-02-2012, 19:25 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | If the box working with other PC and not working with your PC means it is pure PC fault . USB port not functing properly Br - srinibas |
10-03-2012, 03:06 | #5 (permalink) | |
Freak Poster Join Date: Jun 2008 Location: peshawar
Member: 784983 Status: Offline Sonork: 100.1676767 QQ 1125933349 Thanks Meter: 39 | Quote:
go to product Support then go to box tools and then go to Update Firmware and then w to 2m and then Restart your box your prob 100000000% solve | |
10-03-2012, 09:59 | #10 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Karachi pakistan Age: 41
Member: 388647 Status: Offline Sonork: sheerazi Thanks Meter: 161 | 1: uninstall ATF software 2: install this driver VIA_USB2_V270p1-L.zip 3: install ATF software v-7.90 with new atf driver 4: paste & extract this exe to ATF folder AdvanceBox.zip 5: open software & click update important files 6: restart ATF software Last edited by asif ali; 10-03-2012 at 10:07. |
The Following 2 Users Say Thank You to asif ali For This Useful Post: |
10-03-2012, 10:31 | #11 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Purely its a PC fault What probably ? 1 - A to B cable , 2 - USB port , 3 - Driver not properly install , Check these only Br - srinibas | |
10-03-2012, 13:27 | #13 (permalink) | |
Member: 726546 Status: Offline Sonork: 100.1578784 Thanks Meter: 555 | Quote:
im verry happy now im again using my aft box thanks again ( asif ali and angel) special thanks to great men angel Last edited by jawad_anis; 10-03-2012 at 13:34. | |
The Following User Says Thank You to jawad_anis For This Useful Post: |
10-03-2012, 13:40 | #14 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | A cup of tea at Mr.Jawad's shop has just solved it... He he :-) BR |
The Following 5 Users Say Thank You to ..::Angel::.. For This Useful Post: |
