02-25-2014, 08:34 | #1 (permalink) |
Insane Poster Join Date: Dec 2010
Member: 1457979 Status: Offline Thanks Meter: 4 | need help rm-569/N8 Unable to read SP data here the log right after Buscheck Code: Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001060 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 09900207 ID DWORD 1 : F2DE0344 ID DWORD 2 : 89EB2279 ID DWORD 3 : 595B2723 ID DWORD 4 : A7A734C4 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B Checksum FF SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Boot File - Version 012.014.00 Boot File - Revision 0x0003 (3) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0050 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0232 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 Checksum : 06 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0050 ExtID :0000 RevID :0232 Flash Descriptor Manufacturer Code : 00EC Device ID : 0050 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 20000000 (512 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algorithm File - Version 012.014.00 Algorithm File - Revision 0x0003 (3) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231 Scanning Simlock Applet Type... OK ================================================= PA_SIMLOC30 Applet detected Use "Scan Phone" Button to Check if this Phone uses a 15-digit NCK or a 20-digit NCK... ================================================= * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... Code: SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0050 ExtID :0000 RevID :0232 Flash Descriptor Manufacturer Code : 00EC Device ID : 0050 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 20000000 (512 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algorithm File - Version 012.014.00 Algorithm File - Revision 0x0003 (3) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231 Scanning Simlock Applet Type... OK ================================================= PA_SIMLOC30 Applet detected Use "Scan Phone" Button to Check if this Phone uses a 15-digit NCK or a 20-digit NCK... ================================================= * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... ================================================ Basic Phone Information ================================================ MCU Version: V 79_sr1_12w18.5 27-07-12 RM-596 (c) Nokia IMEI Plain : 352847052740899 IMEI Spare : A352847052740890 IMEI SV : 33528470527408945F Phone Model: Nokia N8-00 Category : Classic Phone Phone Type : RM-596 ================================================ Extended Phone Information ================================================ Product Serial Number: C8F307039 Product Code : 0599280 Basic Production Code: 0596829 Long Production SN : 0 MCU SW Version : V 79_sr1_12w18.5 27-07-12 RM-596 (c) Nokia HW Version : 7600 RFIC Version : |Alli_4.3.4 DSP Version : 92_12w18 APE BT Version : HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. AHNE Version : 11 APE SW Core Version : 111.040.1511 Variant Version : 111.040.1511111.040.1511.19.01111.040.1511.C02.01 APE Test Version : 0.162 RETU Version : 40 TAHVO Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : A4:E7:31:64:AF:8C Bluetooth ID : A4:E7:31:64:88:7C CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ Unable to read SP Data.. ================================================ Basic Phone Information ================================================ MCU Version: V 79_sr1_12w18.5 27-07-12 RM-596 (c) Nokia IMEI Plain : 352847052740899 IMEI Spare : A352847052740890 IMEI SV : 33528470527408945F Phone Model: Nokia N8-00 Category : Classic Phone Phone Type : RM-596 ================================================ Extended Phone Information ================================================ Product Serial Number: C8F307039 Product Code : 0599280 Basic Production Code: 0596829 Long Production SN : 0 MCU SW Version : V 79_sr1_12w18.5 27-07-12 RM-596 (c) Nokia HW Version : 7600 RFIC Version : |Alli_4.3.4 DSP Version : 92_12w18 APE BT Version : HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. AHNE Version : 11 APE SW Core Version : 111.040.1511 Variant Version : 111.040.1511111.040.1511.19.01111.040.1511.C02.01 APE Test Version : 0.162 RETU Version : 40 TAHVO Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : A4:E7:31:64:AF:8C Bluetooth ID : A4:E7:31:64:88:7C CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ Unable to read SP Data.. SECURITY_TEST : PASSED CMLA_KEY : PASSED SUPER_DONGLE_TEST : PASSED ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... PHONE_MODE : TEST DCC ID : NOT USED Code: ================================================ Basic Phone Information ================================================ MCU Version: V 79_sr1_12w18.5 27-07-12 RM-596 (c) Nokia IMEI Plain : 352847052740899 IMEI Spare : A352847052740890 IMEI SV : 33528470527408945F Phone Model: Nokia N8-00 Category : Classic Phone Phone Type : RM-596 Changing Phone Mode... ERROR: Selected Mode is NOT APPLICABLE ================================================ Basic Phone Information ================================================ MCU Version: V 79_sr1_12w18.5 27-07-12 RM-596 (c) Nokia IMEI Plain : 352847052740899 IMEI Spare : A352847052740890 IMEI SV : 33528470527408945F Phone Model: Nokia N8-00 Category : Classic Phone Phone Type : RM-596 Changing Phone Mode... ERROR: Selected Mode is NOT APPLICABLE SELFT TEST Start.... SELFT TEST Done.... ----------------------------------------------------- Code: ================================================ Basic Phone Information ================================================ MCU Version: V 79_sr1_12w18.5 27-07-12 RM-596 (c) Nokia IMEI Plain : 352847052740899 IMEI Spare : A352847052740890 IMEI SV : 33528470527408945F Phone Model: Nokia N8-00 Category : Classic Phone Phone Type : RM-596 ================================================ Extended Phone Information ================================================ Product Serial Number: C8F307039 Product Code : 0599280 Basic Production Code: 0596829 Long Production SN : 0 MCU SW Version : V 79_sr1_12w18.5 27-07-12 RM-596 (c) Nokia HW Version : 7600 RFIC Version : |Alli_4.3.4 DSP Version : 92_12w18 APE BT Version : HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. AHNE Version : 11 APE SW Core Version : 111.040.1511 Variant Version : 111.040.1511111.040.1511.19.01111.040.1511.C02.01 APE Test Version : 0.162 RETU Version : 40 TAHVO Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : A4:E7:31:64:AF:8C Bluetooth ID : A4:E7:31:64:88:7C CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED PHONE_MODE : LOCAL DCC ID : NOT USED Then once again SD/CMLA Check Code: AHNE Version : 11 APE SW Core Version : 111.040.1511 Variant Version : 111.040.1511111.040.1511.19.01111.040.1511.C02.01 APE Test Version : 0.162 RETU Version : 40 TAHVO Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : A4:E7:31:64:AF:8C Bluetooth ID : A4:E7:31:64:88:7C CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED CMLA_KEY : PASSED SUPER_DONGLE_TEST : PASSED ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... PHONE_MODE : LOCAL DCC ID : NOT USED |
02-25-2014, 10:27 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, it sounds like a hardware problem. Nokia logo is most of time hardware related in those N8-00, C7-00 and E7-00 etc. BR |
