07-30-2013, 08:58 | #1 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Pakistan TDM
Member: 1330570 Status: Offline Sonork: 100.1611533 Thanks Meter: 408 | Need help >>>> - [SOLVED] then i ready Angel this solution in one post 1. Authorize Phone - it will also backup RPL ... 2. Go to IMEI and LOCKS->SL3 Recovery->Level 2 from Phone 3. After you got your SIMLOCKS ... 4. Full Erase Phone 5. Write Full Flash 6. Write RPL Backup 7. Write Recovered SIMLOCK from ATF SW 8. Use StandAlone SX4 Auth and Write PM 1, 309. i authorize phone , then take recovery , after that i found RPL & SIMlock backup Id file size 1kb , rsa file size 1 kb,RPL 12kb , recoverd backup size 3 kb but these file size is smol if i erese my handset then is these files able to make my handset RPL and simlock back like before thanks in advance |
07-30-2013, 10:48 | #2 (permalink) |
Member: 1330570 Status: Offline Sonork: 100.1611533 Thanks Meter: 408 | My problem solved after take backup full erease phone then flash and write rpl also backup simlock then authorized phone then rpair superdongle now handset completely ok THanks to Mr.Angle |
