10-27-2015, 14:14 | #1 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Nepal Age: 41
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | need KLMAG4FE4B-B002 ext_csd backup file (thanks atf) thanks everybody |
10-29-2015, 07:09 | #4 (permalink) |
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | before write extcsd Code: eMMC Device Information EMMC CID : 1501004D41473446300C2013280C7F02 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 Rev.0xC EMMC NAME: MAG4F0 , S/N: 538126348 EMMC NAME (HEX): 4D414734463000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: MAG4F0_ 538126348_20150904_1150.extcsd Done. Code: eMMC Device Information EMMC CID : 1501004D41473446300C2013280C7F02 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 Rev.0xC EMMC NAME: MAG4F0 , S/N: 538126348 EMMC NAME (HEX): 4D414734463000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: MAG4F0_ 538126348_20150904_1152.extcsd Done. |
10-29-2015, 13:57 | #6 (permalink) |
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | strange problam again.i repair with sdc, download mode ok and flashing done. now when i remove sdc card from phone then phone is not getting on. with sdc card phone is working fine.. |
11-03-2015, 11:07 | #10 (permalink) |
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | i change emmc chip and do same process.but problam is same. with sdc card phone is working good but without sdc card phone is not getting on. |
11-03-2015, 11:20 | #11 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Let me understand, you have changed EMMC, Replace with new one and Why you use Sdc file and Sd Card at this point? If have changed EMMC with other Brand New w/o Fw, you must need of write "Update Firmware" before of mount other time. If is used but working tested before of mount in you phone must need, (if take from other phone need reballing first), of "Factory Reset + Update Firmware" option. From you word: Quote:
BR allumts | |
11-03-2015, 13:57 | #12 (permalink) |
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | look i explain problam. i got phone in dead condition.i remove emmc and done emmc firmware update and format.(now emmc is new and blank ?) then i repair csd and install emmc in phone. then i insert sdc card with 4.4.2 boot in phone and jig. now download mode is ok and i do flash via oc888bus box. flash also ok phone fully on and working to 4.4.2. now i remove sdc card from phone and try to start phone again fully dead not getting power on. again i insert sdc card in phone and try to power on then phone gets on and working. may be emmc is damage i think. then i change new blank emmc. and same process with sdc etc. now is same problam witch was with old emmc. may be you are understand now.please provide me any solution |
11-03-2015, 17:41 | #13 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Yoy first BIG error is Flashing 4 part file + Pit after repair With SD Card Inside. Listen good: 1) Use Sdc File Procedure and Stop, but we have seen you phone Not working, (You after remove EMMC and "Format + Update fw" NO NEED SDC FILE) 2) Use EMMC DIRECT from procedure with NAND_RE# to GND point and later Format + update Firmware, STOP you have NEW EMMC and FORGOT always this SdC file procedure. 3) If have Blank New EMMC where's the problem?, havent Firmware, ok just Write Firmware and Mount in phone, NOT Use this Lol Sdc procedure anymore, FORGOT of this. Goes to read how to use NAND_RE# TP to GND and Repayr EMMC also TOTALLY DEAD: step-step-repair-totally-dead-emmc-via-nand_re-pin-added-emmc FORGOT Sdc File and Sd Card. Hope now is clear BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
