09-26-2013, 09:05 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: heart of Asia
Member: 311316 Status: Offline Thanks Meter: 41 | need live support nokia lumia 900 15:58:12 : ================================================== ==== 15:58:12 : eMMC Test Point Connection Module 15:58:12 : ================================================== ==== 15:58:12 : ================================================== ==== 15:58:12 : 15:58:12 : 1. DO NOT USE THE PHONE"S BATTERY 15:58:12 : 2. Connect the Soldered TP Connections to ATF Box 15:58:12 : 3. Disconnect the USB Cable and Wait until the 15:58:12 : the ATF Software will tell you to Connect the USB. 15:58:12 : 15:58:14 : 15:58:14 : Interface Reset OK! 15:58:14 : eMMC Supported Voltage Range: 15:58:14 : 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V 15:58:14 : 15:58:14 : eMMC Boot Information 15:58:14 : BOOT PARTITION : USER AREA 15:58:14 : PARTITION ACCESS : R/W USER PARTITION 15:58:14 : PERM_BOOT_CFG_PROT: DISABLED 15:58:14 : PWR_BOOT_CFG_PROT : DISABLED 15:58:14 : eMMC FirmW UPDATE : DISABLED 15:58:14 : 15:58:14 : Lumia 800/800C Detected 15:58:14 : 15:58:14 : eMMC Device Information 15:58:14 : Manufacturer ID: HYNIX 15:58:14 : Device Type : Embedded BGA 15:58:14 : Application ID : 4A 15:58:14 : Product Name : HYNIX 15:58:14 : Product Rev : 5.12 15:58:14 : Product SN : 001A8BA8 15:58:14 : Manufactured : January 2011 15:58:14 : 15:58:14 : Card Specific Data 15:58:14 : CSD_STRUCTURE : Extended 15:58:14 : SPEC_VERS : Version 4.1/4.2/4.3 15:58:14 : TAAC : 300 ns 15:58:14 : TRANS_SPEED : 4000000 KHz 15:58:14 : READ_BL_LEN : 512 Bytes 15:58:14 : C_SIZE : HIGH CAPACITY 15:58:14 : WP_GRP_ENABLE : YES 15:58:14 : WRITE_BL_LEN : 512 Bytes 15:58:14 : CONTENT_PROT_APP : NO 15:58:14 : PERM_WRITE_PROTECT: NO 15:58:14 : TMP_WRITE_PROTECT : NO 15:58:14 : 15:58:14 : Writing MBR... 15:58:14 : Write Success! 15:58:14 : Writing DBL... 15:58:47 : Write Success! 15:58:47 : Writing OSBL... 16:00:23 : Write Success! 16:00:23 : 16:00:23 : BOOT Images Written Successfully! 16:00:23 : 16:00:23 : Total Elapsed Time 00:02:11 16:00:56 : 16:00:56 : FOUND: Qualcomm MMC Storage USB Device 16:00:56 : Mounted Drive Number: 2 16:00:56 : 16:00:56 : MBR Entry[0]: 16:00:56 : Flags : 128 16:00:56 : Type : 0x4D - DBL 16:00:56 : Starting Sector: 0x00000001 16:00:56 : Sector Count : 0x000003E8 16:00:56 : MBR Entry[1]: 16:00:56 : Flags : 0 16:00:56 : Type : 0x46 - OSBL 16:00:56 : Starting Sector: 0x000003E9 16:00:56 : Sector Count : 0x00000BB8 16:00:56 : MBR Entry[2]: 16:00:56 : Flags : 0 16:00:56 : Type : 0x0C - AMSS_ADSP 16:00:56 : Starting Sector: 0x00000FA1 16:00:56 : Sector Count : 0x000493E0 16:00:56 : EBR Entry[0]: 16:00:56 : Flags : 0 16:00:56 : Type : 0xEF - PMM 16:00:56 : Starting Sector: 0x0004A386 16:00:56 : Sector Count : 0x00000080 16:00:57 : EBR Entry[1]: 16:00:57 : Flags : 0 16:00:57 : Type : 0x58 - ENC_STORAGE_A 16:00:57 : Starting Sector: 0x0004A406 16:00:57 : Sector Count : 0x00001800 16:00:57 : EBR Entry[2]: 16:00:57 : Flags : 0 16:00:57 : Type : 0x4A - ENC_STORAGE_B 16:00:57 : Starting Sector: 0x00060000 16:00:57 : Sector Count : 0x00001800 16:00:57 : EBR Entry[3]: 16:00:57 : Flags : 0 16:00:57 : Type : 0x4B - ENC_STORAGE_C 16:00:57 : Starting Sector: 0x00061800 16:00:57 : Sector Count : 0x00001800 16:00:58 : EBR Entry[4]: 16:00:58 : Flags : 0 16:00:58 : Type : 0x48 - WP_OS 16:00:58 : Starting Sector: 0x00080000 16:00:58 : Sector Count : 0x01D38FFF 16:01:10 : 16:01:10 : Loading Partition File: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\dbl_RM-801_RM-819.bin 16:01:10 : Writing Partition 0x4D 16:01:10 : Partition 0x4D Write OK 16:01:10 : 16:01:10 : Total Elapsed Time 00:00:00 16:01:16 : 16:01:16 : Loading Partition File: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\osbl_nokia_RM-801_RM-819.bin 16:01:16 : Writing Partition 0x46 16:01:16 : Partition 0x46 Write OK 16:01:16 : 16:01:16 : Total Elapsed Time 00:00:00 16:01:23 : 16:01:23 : Loading Partition File: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\amss_adsp_RM-801_RM-819.bin 16:01:23 : Writing Partition 0x0C 16:01:23 : Partition 0x0C Write OK 16:01:23 : 16:01:23 : Total Elapsed Time 00:00:00 16:01:54 : 16:01:54 : Loading Partition File: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-801\RM801_12221_prod_759_01_boot.esco 16:01:54 : Writing Partition 0x48 16:01:56 : Partition 0x48 Write OK 16:01:56 : 16:01:56 : Total Elapsed Time 00:00:01 cant flash |
09-26-2013, 09:39 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @dexter_mn My dear sir, why are you writing RM-801 files (Lumia 800) to your Lumia 900 phone? Maybe title of thread is wrong? Anyway, here is the problem: 16:01:56 : Total Elapsed Time 00:00:01 It means Windows is not allowing you to write to the phone. Make sure you right-click and give administrator rights to ATF exe |
10-01-2013, 09:59 | #8 (permalink) |
Member: 311316 Status: Offline Thanks Meter: 41 | but still not power on 11:30:38 : Loading Partition File: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\dbl_RM-801_RM-819.bin 11:30:38 : Writing Partition 0x4D 11:30:39 : Partition 0x4D Write OK 11:30:39 : 11:30:39 : Total Elapsed Time 00:00:00 11:30:46 : 11:30:46 : Loading Partition File: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\osbl_nokia_RM-801_RM-819.bin 11:30:46 : Writing Partition 0x46 11:30:47 : Partition 0x46 Write OK 11:30:47 : 11:30:47 : Total Elapsed Time 00:00:00 11:30:52 : 11:30:52 : Loading Partition File: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\amss_adsp_RM-801_RM-819.bin 11:30:52 : Writing Partition 0x0C 11:31:21 : Partition 0x0C Write OK 11:31:21 : 11:31:21 : Total Elapsed Time 00:00:28 11:32:01 : 11:32:01 : Loading Partition File: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-801\RM801_12221_prod_608_03_boot.esco 11:32:01 : Writing Partition 0x48 11:33:46 : Partition 0x48 Write OK 11:33:46 : 11:33:46 : Total Elapsed Time 00:01:44 |
10-01-2013, 21:08 | #9 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, Provide us more details on your problem. What was the actual phone's problem? From your logs - you were getting this error on flashing: ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED ??? ... or it was just dead boot and you make boot repair ? |
10-02-2013, 14:51 | #10 (permalink) |
Member: 311316 Status: Offline Thanks Meter: 41 | phone was network locked here flashed OSBL via usb 20:20:06 : Sending OSBL Certificate 20:20:06 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 20:20:06 : Certificate Size: 452 Bytes 20:20:06 : Status : WRITE OSBL CERTIFICATE SUCCESS 20:20:06 : 20:20:06 : Sending OSBL Data Blocks 20:20:06 : [BLOCK 1 0x00000000~0x000D4A27] 20:20:06 : Data Size: 0x000D4A28 Bytes 20:20:06 : SHA-256 : AC6137483D7F4A413CE1894622573FE6 20:20:06 : ---------- : E9D27DD379587C9A910B92459AE0FDB5 20:20:07 : Status : OSBL WRITE SUCCESS 20:20:07 : 20:20:07 : Flashing Done! 20:20:08 : Total Flashing Time (Erase + Flashing) : 00:00:01 when unlocking 20:20:58 : Dumping AMSS FAT16 Region 20:20:58 : Please wait for 15-20 Seconds... 20:21:14 : 20:21:14 : WARNING: Patch Bit NOT FOUND! 20:21:14 : Maybe Phone is already UNLOCKED! 20:40:27 : Loading Partition File: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\dbl_RM-801_RM-819.bin 20:40:27 : Writing Partition 0x4D 20:40:27 : Partition 0x4D Write OK 20:41:38 : Loading Partition File: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\osbl_nokia_RM-801_RM-819.bin 20:41:38 : Writing Partition 0x46 20:41:39 : Partition 0x46 Write OK 20:41:39 : 20:41:39 : Total Elapsed Time 00:00:00 20:41:45 : 20:41:45 : Loading Partition File: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\amss_adsp_RM-801_RM-819.bin 20:41:45 : Writing Partition 0x0C 20:42:15 : Partition 0x0C Write OK 20:42:15 : 20:42:15 : Total Elapsed Time 00:00:29 unlocked here 20:42:41 : Dumping AMSS FAT16 Region 20:42:41 : Please wait for 15-20 Seconds... 20:42:57 : Patch Bit Found... 20:42:57 : Patch Bit Found... 20:42:58 : Total Patch Bits Found: 2 20:42:58 : Patching AMSS... 20:43:00 : 20:43:00 : 20:43:00 : SP Unlock Done! 20:43:00 : 20:43:00 : PIN: 00000000 20:43:00 : PUK: 0000000000 20:43:00 : 20:43:00 : Total Elapsed Time 00:00:22 but cant normal boot just nokia logo looped when flash via DLOAD 20:48:55 : Windows Phone Lumia Flasher 20:48:55 : ================================================== ==== 20:48:55 : 20:48:55 : If the Phone is ALIVE 20:48:55 : 1. Power On the Phone and Connect it to the USB Port 20:48:55 : 20:48:55 : If the Phone is DEAD 20:48:55 : 1. Press and Hold the VOLUME UP button 20:48:55 : 2. Connect it to the USB Port while still Pressing 20:48:55 : the VOLUME UP button 20:48:55 : 3. Continue to Press the VOLUME UP button for 8 more 20:48:55 : seconds 20:48:55 : ================================================== ==== 20:48:55 : 20:49:10 : 20:49:10 : Sending OSBL Certificate 20:49:10 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 20:49:10 : Certificate Size: 452 Bytes 20:49:11 : Status : WRITE OSBL CERTIFICATE FAILED |
10-02-2013, 17:04 | #11 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @dexter_mn That is okay, you wrote OSBL QUALCOMM File. Code: 20:20:06 : Sending OSBL Certificate 20:20:06 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 20:20:06 : Certificate Size: 452 Bytes 20:20:06 : Status : WRITE OSBL CERTIFICATE SUCCESS 20:20:06 : 20:20:06 : Sending OSBL Data Blocks 20:20:06 : [BLOCK 1 0x00000000~0x000D4A27] 20:20:06 : Data Size: 0x000D4A28 Bytes 20:20:06 : SHA-256 : AC6137483D7F4A413CE1894622573FE6 20:20:06 : ---------- : E9D27DD379587C9A910B92459AE0FDB5 20:20:07 : Status : OSBL WRITE SUCCESS 20:20:07 : 20:20:07 : Flashing Done! 20:20:08 : Total Flashing Time (Erase + Flashing) : 00:00:01 Code: 20:20:58 : Dumping AMSS FAT16 Region 20:20:58 : Please wait for 15-20 Seconds... 20:21:14 : 20:21:14 : WARNING: Patch Bit NOT FOUND! 20:21:14 : Maybe Phone is already UNLOCKED! Code: 20:40:27 : Loading Partition File: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\dbl_RM-801_RM-819.bin 20:40:27 : Writing Partition 0x4D 20:40:27 : Partition 0x4D Write OK 20:41:38 : Loading Partition File: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\osbl_nokia_RM-801_RM-819.bin 20:41:38 : Writing Partition 0x46 20:41:39 : Partition 0x46 Write OK 20:41:39 : 20:41:39 : Total Elapsed Time 00:00:00 20:41:45 : 20:41:45 : Loading Partition File: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\amss_adsp_RM-801_RM-819.bin 20:41:45 : Writing Partition 0x0C 20:42:15 : Partition 0x0C Write OK 20:42:15 : 20:42:15 : Total Elapsed Time 00:00:29 Code: 20:48:55 : Windows Phone Lumia Flasher 20:48:55 : ================================================== ==== 20:48:55 : 20:48:55 : If the Phone is ALIVE 20:48:55 : 1. Power On the Phone and Connect it to the USB Port 20:48:55 : 20:48:55 : If the Phone is DEAD 20:48:55 : 1. Press and Hold the VOLUME UP button 20:48:55 : 2. Connect it to the USB Port while still Pressing 20:48:55 : the VOLUME UP button 20:48:55 : 3. Continue to Press the VOLUME UP button for 8 more 20:48:55 : seconds 20:48:55 : ================================================== ==== 20:48:55 : 20:49:10 : 20:49:10 : Sending OSBL Certificate 20:49:10 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 20:49:10 : Certificate Size: 452 Bytes 20:49:11 : Status : WRITE OSBL CERTIFICATE FAILED now connect TEST POINTS and Repair Boot loader if you get any error - post here... make sure phone's battery is fully charged before you flash it and your flash files are downloaded OK and are not corrupted. BR |
10-02-2013, 17:45 | #12 (permalink) |
Member: 311316 Status: Offline Thanks Meter: 41 | DLOAD via tp ================================================== ==== 17:30:29 : eMMC Test Point Connection Module 17:30:29 : ================================================== ==== 17:30:29 : ================================================== ==== 17:30:29 : 17:30:29 : 1. DO NOT USE THE PHONE"S BATTERY 17:30:29 : 2. Connect the Soldered TP Connections to ATF Box 17:30:29 : 3. Disconnect the USB Cable and Wait until the 17:30:29 : the ATF Software will tell you to Connect the USB. 17:30:29 : 17:30:32 : 17:30:32 : Interface Reset OK! 17:30:32 : eMMC Supported Voltage Range: 17:30:32 : 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V 17:30:32 : 17:30:32 : eMMC Boot Information 17:30:32 : BOOT PARTITION : USER AREA 17:30:32 : PARTITION ACCESS : R/W USER PARTITION 17:30:32 : PERM_BOOT_CFG_PROT: DISABLED 17:30:32 : PWR_BOOT_CFG_PROT : DISABLED 17:30:32 : eMMC FirmW UPDATE : DISABLED 17:30:32 : 17:30:32 : Lumia 800/800C Detected 17:30:32 : 17:30:32 : eMMC Device Information 17:30:32 : Manufacturer ID: HYNIX 17:30:32 : Device Type : Embedded BGA 17:30:32 : Application ID : 4A 17:30:32 : Product Name : HYNIX 17:30:32 : Product Rev : 5.12 17:30:32 : Product SN : 001A8BA8 17:30:32 : Manufactured : January 2011 17:30:32 : 17:30:32 : Card Specific Data 17:30:32 : CSD_STRUCTURE : Extended 17:30:32 : SPEC_VERS : Version 4.1/4.2/4.3 17:30:32 : TAAC : 300 ns 17:30:32 : TRANS_SPEED : 4000000 KHz 17:30:32 : READ_BL_LEN : 512 Bytes 17:30:32 : C_SIZE : HIGH CAPACITY 17:30:32 : WP_GRP_ENABLE : YES 17:30:32 : WRITE_BL_LEN : 512 Bytes 17:30:32 : CONTENT_PROT_APP : NO 17:30:32 : PERM_WRITE_PROTECT: NO 17:30:32 : TMP_WRITE_PROTECT : NO 17:30:32 : 17:30:32 : Writing MBR... 17:30:32 : Write Success! 17:30:32 : Writing DBL... 17:31:05 : Write Success! 17:31:05 : Writing OSBL... 17:32:41 : Write Success! 17:32:41 : 17:32:41 : BOOT Images Written Successfully! 17:32:41 : 17:32:41 : Total Elapsed Time 00:02:12 2 variant files check Flash File Checksum Verification ================================================== ==== RM801_12w22_1_prod_generic_nokia_osbl.esco: CHECKSUM PASSED RM801_12w22_1_prod_generic_amss.esco: CHECKSUM PASSED RM801_12w22_1_prod_generic_adsp.esco: CHECKSUM PASSED RM801_12221_prod_759_01_boot.esco: CHECKSUM PASSED RM801_12w22_1_prod_generic_user_area_erase.esco: CHECKSUM PASSED ================================================== ==== Verification Done... ================================================== ==== Variant Details : Nokia 800 RM-801 Country Variant CIS AZ MATT BLACK V2 Software Version : 1750.0805.8779.12221 Product Type : RM-801 Product Code : 059N620 Variant Version : 006 ================================================== ==== Flash File Checksum Verification ================================================== ==== RM801_12w22_1_prod_generic_nokia_osbl.esco: CHECKSUM PASSED RM801_12w22_1_prod_generic_amss.esco: CHECKSUM PASSED RM801_12w22_1_prod_generic_adsp.esco: CHECKSUM PASSED RM801_12221_prod_608_03_boot.esco: CHECKSUM PASSED RM801_12w22_1_prod_generic_user_area_erase.esco: CHECKSUM PASSED ================================================== ==== Verification Done... when flash error below 17:34:18 : If the Phone is ALIVE 17:34:18 : 1. Power On the Phone and Connect it to the USB Port 17:34:18 : 17:34:18 : If the Phone is DEAD 17:34:18 : 1. Press and Hold the VOLUME UP button 17:34:18 : 2. Connect it to the USB Port while still Pressing 17:34:18 : the VOLUME UP button 17:34:18 : 3. Continue to Press the VOLUME UP button for 8 more 17:34:18 : seconds 17:34:18 : ================================================== ==== 17:34:18 : 17:34:25 : 17:34:25 : Sending OSBL Certificate 17:34:25 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 17:34:25 : Certificate Size: 452 Bytes 17:34:25 : Status : WRITE OSBL CERTIFICATE FAILED i cant determent battery percent , just charged via ac few minutes is this error depending battery???? |
10-03-2013, 08:27 | #13 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @dexter_mn Next time if you get error: 20:21:14 : WARNING: Patch Bit NOT FOUND! 20:21:14 : Maybe Phone is already UNLOCKED! Just use search button in forum or GOOGLE. Solution was very simple, just write back DLOAD to phone and flash phone with latest firmware before trying to unlock again. I don't know why you tried to write boot files if the phone was 100% working. You only need to write BOOT files if your phone is dead... Just follow instructions here: http://forum.gsmhosting.com/vbb/f609...epair-1673102/ |
