Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 11-25-2013, 15:42   #1 (permalink)
Maninder_111's Avatar
Member: 687144
Sonork: 1614780
Thanks Meter: 228
need Lumia 620 driver - [SOLVED]
need Lumia 620 driver .............
Old 11-27-2013, 05:32   #2 (permalink)
Member: 1476282
Thanks Meter: 14
same problm here .... plz ATF team give us Lumia 620 flashing driver
Old 11-27-2013, 05:36   #3 (permalink)
Sukh007's Avatar
Member: 1481018
Sonork: 100.165460
Thanks Meter: 222
ATF team plz Give Lumia 620 flashing driver plzzzzzzzzzzzzzzzz
Old 11-27-2013, 05:41   #4 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
all drivers are here:
C:\AdvanceBox Turbo Flasher\Driver\Lumia and Asha Phone Drivers\
Old 11-27-2013, 05:50   #5 (permalink)
Sukh007's Avatar
Member: 1481018
Sonork: 100.165460
Thanks Meter: 222
i also try this when i select driver no take driver showing ms ,,cannot insttal this hardware ,,[
Old 11-27-2013, 05:55   #6 (permalink)
Member: 687144
Sonork: 1614780
Thanks Meter: 228
Lumia 620 does not accept this driver
Old 11-27-2013, 06:00   #7 (permalink)
Registered User
Member: 1219582
Thanks Meter: 10
Originally Posted by Maninder_111 View Post
Nokia 620 does not accept this driver
ZunePackage for Lumai Use Driver
Old 11-27-2013, 06:10   #8 (permalink)
Member: 687144
Sonork: 1614780
Thanks Meter: 228
Mr. Alimul this not driver lumia 620 give proper driver
Old 11-27-2013, 06:17   #9 (permalink)
Sukh007's Avatar
Member: 1481018
Sonork: 100.165460
Thanks Meter: 222
i hv same problme bro plz Atf team Give solution
use zune driver and update lumia driver by Driver doc software But no way................
Old 11-27-2013, 06:59   #10 (permalink)
Member: 651945
@ALL
1. Right-Click on RM-846| Nokia Lumia 620
2. Select Properties
3. Select Details Tab
4. Choose Property ---> "Hardware Ids"
5. Make Screenshot
6. Post Here
Old 11-27-2013, 07:31   #11 (permalink)
Member: 687144
Sonork: 1614780
Thanks Meter: 228
Old 11-27-2013, 07:50   #12 (permalink)
Member: 687144
Sonork: 1614780
Thanks Meter: 228
plz urgent solution ...............
Old 11-27-2013, 07:56   #13 (permalink)
Member: 651945
@Maninder_111
1. Make Sure Battery is Charged more than 50%
2. Power OFF Phone
3. Disconnect USB Cable
4. Put Battery to phone and HOLD VOLUME UP BUTTON
5. While still holding volume UP Button, Connect USB cable to phone
*** At this point windows will find another device, the drivers for this device can
be found here:
Flash Phone via DEAD MODE,, meaning phone is off...
2. Power OFF Phone
5. Click "FLASH" button in ATF Software... Click OK OK...
6. While still holding volume UP Button, Connect USB cable to phone
It will start flashing
Old 11-27-2013, 08:13   #14 (permalink)
Member: 687144
Sonork: 1614780
Thanks Meter: 228
same problm ...................................
not my problm solve ....
Old 11-27-2013, 08:44   #15 (permalink)
Member: 651945
@Maninder_111
wow QUALCOMM MSM DEVICE
Can you should be the VID/PID of that one?
Same as Post #10
Page generated in 0.28318 seconds with 8 queries
