04-18-2016, 15:12 | #1 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Online Sonork: 57528:debeliamark Thanks Meter: 1,034 | Need Lumia 640 DS / RM-1077 BIG BOOT file If someone have - let me know. WBR, DebeliaMark, BG P.S. EMMC still look good: Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010038474E443352018F4858874221 CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : 8GND3R Product Rev : 0.1 Product SN : 8F485887 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010038474E443352018F4858874221.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Dumping Custom Region Please wait for some time... Partition Selected: USER AREA (eMMC Clock 15000000 Hz) Custom Block Read OK File Saved: C:\AdvanceBox Turbo Flasher\eMMC\Recovered\rm-1077-357779064347200_0x00000000_0x000FFFFF.bin Total Elapsed Time 00:06:15 |
04-21-2016, 14:49 | #2 (permalink) |
Member: 4627 Status: Online Sonork: 57528:debeliamark Thanks Meter: 1,034 | I'm still waiting someone to give Lumia 640 DS BIG BOOT file ... ... due to no way to repair it via USB: It's tested with full or empty battery, with different PC-s ( this on picture is clean reinstalled VAIO ) ... same. Repair process stuck on Firehose Payload ... Any help or advise is welcome. |
04-26-2016, 10:06 | #3 (permalink) |
Member: 4627 Status: Online Sonork: 57528:debeliamark Thanks Meter: 1,034 | A step forward, but ... still nothing Brrr ... after eMMC resoldering, now process goes to next step, but: phone is not repaired .... DebeliaMark, BG |
05-20-2016, 05:44 | #6 (permalink) |
Member: 4627 Status: Online Sonork: 57528:debeliamark Thanks Meter: 1,034 | Unfortunately i can't achieve success last time with this phone ... We all hope that sometime in near future BIG BOOT about will be prepared from ATF developers... but who know, anyway Microsoft soldout mobilephone division ( formely Nokia Mobile Phones ) to FoxConn subsidary ... and no more Lumia-s are expected ... |
