02-27-2014, 14:03 | #5 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @mahesh_patel361 Already posted SDC File. Use it to get phone into DOWNLOAD MODE... Then FLASH Correctly with ODIN using correct FLASH FILES and DO NOT USE "CUSTOM FIRMWARE" |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
02-27-2014, 15:07 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @mahesh_patel361 I have N9005 Note 3 Phone with eMMC disabled and it ALWAYS BOOTS via SD Card if eMMC is not OK... This is because it is programmed inside Qualcomm QFUSE BOOT_CONFIG to allow SDC3 BOOTING if SDC1 is not OK... In other words, SD Card booting will work even if you REMOVE EMMC CHIP FROM PHONE PCB. Also, since your phone was only released on 4.3 and nothing lower, then there should be no reason for my SDC Image not to work, unless of course the problem of your phone is HARDWARE. |
