01-13-2013, 20:11 | #1 (permalink) |
Freak Poster Join Date: Mar 2010 Location: In Search of free BB5 rpl
Member: 1248595 Status: Offline Sonork: 100.1607313 Thanks Meter: 99 | Nees PM file Of RM-625 <<< SOLVED >>> First i update important files but not seen this file....So i need badly file for this set. Here is i need for this for.... Code: ================================================ Basic Phone Information ================================================ MCU Version: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia IMEI Plain : 35832103XXXXXX4 IMEI Spare : A35XX21XX371XXX0 IMEI SV : 3X5X3XX10X37XXx41XF Phone Model: Nokia 5233 Category : Classic Phone Phone Type : RM-625 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Long Production SN : 0 MCU SW Version : V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia RFIC Version : 17141716 DSP Version : ICPR72_11WK13 AHNE Version : 11 APE SW Core Version : V 51.1.002 Variant Version : V 51.1.002V 51.1.002 V 51.1.002 APE Test Version : eno_version RETU Version : 16 TAHVO Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 Bluetooth ID : C8:97:9F:0D:2E:48 CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : ENCRYPTED PHONE_MODE : TEST DCC ID : NOT USED SORRY FOR DOUBLE POST. Delete one post Last edited by MTK CHIP; 01-13-2013 at 20:18. Reason: Add double |
01-14-2013, 10:47 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @MTK CHIP There is GENERIC PM inside SX4 Folder, which you can use for almost all Symbian phones BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
01-14-2013, 12:48 | #4 (permalink) |
Member: 1248595 Status: Offline Sonork: 100.1607313 Thanks Meter: 99 | @ Angle Before i post thread i checked all things. Also i do 2 times update important files but not seen this file. I need this file from u r side. |
01-14-2013, 13:12 | #5 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Its here: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\GENERIC_1_309.pm BR |
