No ATF Box Found(Solution Here) http://i148.photobucket.com/albums/s...O_1978/One.jpg Go to device manager http://i148.photobucket.com/albums/s...O_1978/Two.jpg Box Eeprom Damaged Go This Root Folder http://i148.photobucket.com/albums/s...1978/Three.jpg Open Mprog(Careful Dont Connect any Other boxs(ONLY ATF) http://i148.photobucket.com/albums/s..._1978/Four.jpg |
Go This Root(C:\AdvanceBox Turbo Flasher\Driver\MProg 3.5 Release\Templates) And Select This New Eeprom File http://i148.photobucket.com/albums/s..._1978/Five.jpg http://i148.photobucket.com/albums/s...O_1978/Six.jpg http://i148.photobucket.com/albums/s...1978/seven.jpg http://i148.photobucket.com/albums/s...1978/Eight.jpg After Update Eeprom Open ATF Exe (Look Here) http://i148.photobucket.com/albums/s..._1978/NINE.jpg Aft Said Need To Update New Atf Driver!!!! Go To Device Manager Then Update Ur Atf Driver C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS http://i148.photobucket.com/albums/s...DO_1978/NE.jpg After Make Update Driver We Must Restart Ur Pc.Now Box Ready To Use And Serial Number Restored http://i148.photobucket.com/albums/s...O_1978/TEN.jpg |
good information for all the atf users brooooooooooooooooooo |
good information thanksssssssssssssssssssss |
Thanks for this useful information.............. |
plz i hav problem locke this pics http://www.img.gem-flash.com/images/...9670573374.jpg |
http://i148.photobucket.com/albums/s...O_1978/xxx.jpg dont worry! go this root D:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers Run Remove_ATF_Drivers.bat Wait 5 Seconds Now Atf Box Driver Removed Ur Pc Reconnect Box Now Show Update Driver U Can Select Driver In This Root D:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS |
Machine worked 100/100 A thank my brother Greetings to a team Advance:p:p:p:p:p http://www.img.gem-flash.com/images/...4242845685.jpg |
you've just solved my problem |
IN THIS step can i rename the advace turbo flasher in the product discription for example the name of owr shope for security purposed http://i148.photobucket.com/albums/s...O_1978/Six.jpg |
a nice info mate..... thanks |
