04-27-2013, 14:03 | #1 (permalink) |
Insane Poster Join Date: Nov 2008
Member: 911152 Status: Offline Thanks Meter: 4 | Nokia 100 RH-130 i've seen it's listed under the infineon models. WHen i switch to that module from the list an ASCII art in the log window shows me to use the 10 pin connector on the ATF Box. Yet i have ATF Nitro which doesn't have that additional port. is there anything that can be done? can i still flash the phone? what operations are supported for such device? can i read the internal flash? |
04-27-2013, 14:12 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | if you are using atf nitro/lightning you should not be seeing that ascii art... just connect fbus cable to your atf nitro/lightning and flash the phone. br |
The Following User Says Thank You to Advance-Box For This Useful Post: |
