04-27-2013, 05:37 | #1 (permalink) | |||
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | Nokia 100 - (rh-130) cant flash atf phone status cant send BOX: ATF BIG stock in (erasing) & HANG ATF GUI Quote:
04-27-2013, 14:16 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, did you try with different version of files ? |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
04-29-2013, 09:20 | #4 (permalink) | |
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | same problem................ Quote:
04-29-2013, 11:22 | #5 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @MARVZ_TG It stops at same address everytime, this is maybe hardware problem in the phone. However, I will check more on it... BR |
04-29-2013, 13:47 | #6 (permalink) |
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | YES I THINK 50% HW PROBLEM BECAUSE I TRY different TOOLS FOR NOKIA like cyclone.hwk,best. SAME PROBLEM or this phone have new protocol. |
08-26-2015, 18:39 | #8 (permalink) |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | i have the same problem phone was working before Code: Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: D:\phone_directory\Nokia\Phoenix\Products\RH-130\rh130_004.300 Data Block Found... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... |
