Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 07-13-2012, 12:25   #1 (permalink)
vignesharmy55's Avatar
Member: 1531954
Sonork: 100.1619337
Nokia 100 rm-130 on /off problem
I HAVE ONE MOBILE WITH ON/OFF PROBLEM I FLASHED WITH ATF BUT AFTER FLASH SAME PROBLEM HOW TO SOLVE THIS PROBLEM?
FLASH LOG:
VBATT Powering Down <<<<
VBATT Powering Up   >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
                  TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-130\rh130_003.250
 FIRMWARE Image Found...
Number of Sections: 03
FIRMWARE Certificate Block Sent Successfully...
 Processing Section 01 of 03
FIRMWARE Erase Block: 0x00800000~0x00A0FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 2162688 bytes
Data Checksum: CBE9
Uploading Data Blocks to phone...
FIRMWARE Data Blocks uploaded to phone...
 Processing Section 02 of 03
FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE
Start Erasing...
Block Erase Done...
Data Size: 2329984 bytes
Data Checksum: 4ACF
 Processing Section 03 of 03
FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-130\rh130_003.25ua
 PPM Image Found...
Number of Sections: 01
PPM Certificate Block Sent Successfully...
 Processing Section 01 of 01
PPM Erase Block: 0x00210000~0x0041B83E
Start Erasing...
Block Erase Done...
Data Size: 2144320 bytes
Data Checksum: F600
PPM Data Blocks uploaded to phone...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-130\rh1300_nai03.25ua
 CONTENT Image Found...
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x00EB0000~0x00F06DFE
Start Erasing...
Block Erase Done...
Data Size: 355840 bytes
Data Checksum: 53F8
CONTENT Data Blocks uploaded to phone...
Exit Flash Mode Done...
Time Elapse : 00:02:28
    You must Factory Reset the phone to enable the
   ringtones and other  customized settings to work
 Waiting For Phone to go Online...
 5,  4,  3,  2,  1...
MCU: V 03.25 16-09-11 RH-130 (c) Nokia
IMEI: 359755044877948
Product Serial Number: F055D69AI
Product Code         : 059J2D3
Module Code          : 0204875
Basic Production Code: 059F6X3
PPM SW Version       : V 03.25 16-09-11 RH-130 (c) Nokia UA
ADSP Version         : p V 03.25\n16-09-11\nRH-130\n(c) NMP\nua
MCU SW Version       : V 03.25 16-09-11 RH-130 (c) Nokia
HW Version           : 3051
UEM Version          : 1328
UPP Version          : 8850
LCD Version          : WIN:BARACOAv95 NT39121
  ********** SIMLOCK INFO  **********
CONFIG_DATA  : 0010100000000000
PROFILE_BITS : 0000000000040002
ASIC         : 11
PROVIDER     : Default Test Operator
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST               : PASSED
FACTORY SET TO : Full Factory Set
 OK
FACTORY SET TO : User Data
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Service Center
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : Production Tune
 OK
Old 07-13-2012, 18:13   #2 (permalink)
sahassan82's Avatar
Member: 116955
Sonork: 100.1604268
try with Latest 3.91 Firmware
Nokia Firmware Nokia 100 RH-130_dp_v01.70_MCUSW03.91
Old 07-13-2012, 18:18   #3 (permalink)
Member: 1706168
Sonork: 100.1619095
Brother check your SIM card.Infenoen phones have this problem with some sim cards.
Old 07-14-2012, 12:28   #4 (permalink)
Member: 1531954
Sonork: 100.1619337
hello bro with sim or with out sim same problem
Old 07-14-2012, 17:57   #5 (permalink)
Member: 1706168
Sonork: 100.1619095
I think it will be hardware problem search on google.bye
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.22403 seconds with 11 queries
