09-30-2013, 21:37 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Age: 39
Member: 738945 Status: Offline Thanks Meter: 58 | nokia 101 LCD TESTFAILED after flash ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: I:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_006.650 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00000000~0x0001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24576 bytes Data Checksum: F5BE Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00800000~0x00BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4128768 bytes Data Checksum: D598 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1697536 bytes Data Checksum: 047E Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: I:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_006.65ic PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00100000~0x005CFBFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5045248 bytes Data Checksum: 4DBE Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: I:\Program Files\Nokia\Phoenix\Products\RM-769\rm7690_nai06.65ic CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00E60000~0x00F122BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 729792 bytes Data Checksum: 414E Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:04:13 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 06.65 07-11-11 RM-769 (c) Nokia IMEI: 358962052005161 Product Serial Number: C9B3397BI Product Code : 059K1X2 Module Code : 0204874 Basic Production Code: 059R3M2 PPM SW Version : V 06.65 07-11-11 RM-769 (c) Nokia IC ADSP Version : p V 06.65\n07-11-11\nRM-769\n(c) NMP\nic MCU SW Version : V 06.65 07-11-11 RM-769 (c) Nokia HW Version : 3000 UEM Version : 1328 UPP Version : 8850 LCD Version : TINAMA:TIANMAv8A NT39121 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : FAILED Phone Cannot Enter Normal Mode if LCD is Damaged or LCD is not Properly Connected to the Main PCB FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
10-01-2013, 06:43 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | @ abdgsm nokia 101 LCD TESTFAILED after flash OK what was B4 flash ? is it not need to know for us ? Check LCD Br - srinibas |
10-28-2013, 13:15 | #7 (permalink) |
Member: 738945 Status: Offline Thanks Meter: 58 | this is the log before flash : ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020422 Library Version : 00030119 Box Type : ATF Lightning Box Firmware : LogiCore 10.3.80 Software Version : v10.30 AdvanceBox SN : D09D60C69B8E92******** Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done MCU: V 07.70 18-10-12 RM-769 (c) Nokia IMEI: 358962058065086 Product Serial Number: CBA598EBI Product Code : 059K1X2 Module Code : 0204874 Basic Production Code: 059R3M2 PPM SW Version : V 07.70 18-10-12 RM-769 (c) Nokia EC ADSP Version : p V 07.70\n18-10-12\nRM-769\n(c) NMP\nec MCU SW Version : V 07.70 18-10-12 RM-769 (c) Nokia HW Version : 3000 UEM Version : 1328 UPP Version : 8850 LCD Version : TINAMA:BARACOAv8F NT39121 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : ÿ MASTER_CODE : 4517420161 PHONE_MODE : LOCAL ================================================== ==== Selected VPL File: RM769_059F6L6_06.65_001.vpl ================================================== ==== Variant Details : BTR DS EU W SD Software Version : 06.65 Product Type : RM-769 Product Code : 059F6L6 Variant Version : 001 after flash : VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: I:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_006.650 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00000000~0x0001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24576 bytes Data Checksum: F5BE Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00800000~0x00BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4128768 bytes Data Checksum: D598 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1697536 bytes Data Checksum: 047E Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: I:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_006.65ic PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00100000~0x005CFBFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5045248 bytes Data Checksum: 4DBE Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: I:\Program Files\Nokia\Phoenix\Products\RM-769\rm7690_nai06.65ic CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00E60000~0x00F122BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 729792 bytes Data Checksum: 414E Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:04:10 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 06.65 07-11-11 RM-769 (c) Nokia IMEI: 358962058065086 Product Serial Number: CBA598EBI Product Code : 059K1X2 Module Code : 0204874 Basic Production Code: 059R3M2 PPM SW Version : V 06.65 07-11-11 RM-769 (c) Nokia IC ADSP Version : p V 06.65\n07-11-11\nRM-769\n(c) NMP\nic MCU SW Version : V 06.65 07-11-11 RM-769 (c) Nokia HW Version : 3000 UEM Version : 1328 UPP Version : 8850 LCD Version : TINAMA:TIANMAv8F NT39121 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : FAILED |
10-28-2013, 14:55 | #9 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | and here is the latest version...(currently I am using this version w/o any issue) Nokia 101 7.70 (RM-769) - Download - 4shared - Muhammad Nasir Javed wBr, Muhammad Nasir Javed |
10-28-2013, 15:50 | #10 (permalink) | |
Freak Poster Join Date: Jan 2007
Member: 433942 Status: Offline Thanks Meter: 35 | Quote:
But : ST_LCD_TEST : FAILED Try To Change Lcd | |
10-31-2013, 08:08 | #11 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Respected Bro try The Follow Trick.. Quote:
As i have said above please try the following link i hope your problem will be solved i had many Mobiles In L.C.D Test Failed and Recovered if the latest version don't work then try in Hardware. http://forum.gsmhosting.com/vbb/f148...ution-1568204/ | |
