Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-18-2014, 13:12   #1 (permalink)
.::EXTREME::.'s Avatar
Member: 1619462
Sonork: 100.1606509
Thanks Meter: 1,517
Nokia 101 Only Blinking Nokia, After flashing.
After flashing shows Only Blinking Nokia and lights on keypad,
Where im wrong?
Need Your Help.
VBATT Powering Down <<<<
VBATT Powering Up   >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
                  TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: STMicroelectronics
Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_008.100
 Data Block Found...
Number of Sections: 03
IMAGE Certificate Block Sent Successfully...
 Processing Section 01 of 03
IMAGE Erase Block: 0x00000000~0x0001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 24576 bytes
Data Checksum: F5BE
Uploading Data Blocks to phone...
IMAGE Data Blocks uploaded to phone...
 Processing Section 02 of 03
IMAGE Erase Block: 0x00800000~0x00BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 4128768 bytes
Data Checksum: 676D
 Processing Section 03 of 03
IMAGE Erase Block: 0x00C5D000~0x00E5FFFE
Start Erasing...
Block Erase Done...
Data Size: 1697536 bytes
Data Checksum: 2FCD
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_008.10mh
 Data Block Found...
Number of Sections: 01
 Processing Section 01 of 01
IMAGE Erase Block: 0x00100000~0x0061853E
Start Erasing...
Block Erase Done...
Data Size: 5342528 bytes
Data Checksum: 1710
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm7690_nai08.10mh_nlt
 Data Block Found...
IMAGE Erase Block: 0x00E60000~0x00F49FFE
Start Erasing...
Block Erase Done...
Data Size: 958464 bytes
Data Checksum: 6418
Exit Flash Mode Done...
Time Elapse : 00:04:30
    You must Factory Reset the phone to enable the
   ringtones and other  customized settings to work
 Waiting For Phone to go Online...
 5,  4,  3,  2,  1...
MCU: V 08.10 02-04-13 RM-769 (c) Nokia
IMEI: 359770042262969
Product Serial Number: 07D503DBI
Product Code         : 059G7F9
Module Code          : 0204874
Basic Production Code: 059M8W5
PPM SW Version       : V 08.10 02-04-13 RM-769 (c) Nokia MH
ADSP Version         : p+V 08.10\n02-04-13\nRM-769\n(c) NMP\nmh_nlt
MCU SW Version       : V 08.10 02-04-13 RM-769 (c) Nokia
HW Version           : 3000
UEM Version          : 1328
UPP Version          : 8850
LCD Version          : SDI:BOHAIv93 NT39121
  ********** SIMLOCK INFO  **********
CONFIG_DATA  : 0010100000000000
PROFILE_BITS : 0000000000040002
ASIC         : 11
PROVIDER     : Default Test Operator
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST               : PASSED
FACTORY SET TO : Full Factory Set
 OK
FACTORY SET TO : User Data
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Service Center
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : Production Tune
 OK
Page generated in 0.09659 seconds with 9 queries
