12-06-2014, 12:06 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: Sukabumi
Member: 1594457 Status: Offline Sonork: 100.1646470 Thanks Meter: 145 | Nokia 1030 detected QDloader 9008 |
The Following User Says Thank You to lasergsm For This Useful Post: |
12-06-2014, 14:52 | #2 (permalink) |
Freak Poster Join Date: Dec 2012 Location: UFI#Wellcome Worlwide UFiXers
Member: 1853929 Status: Offline Sonork: 1653495 Thanks Meter: 426 | Allready repair done this device, tried my Step: Jtag methode will more easy, If your ATF not activated JTAG yet, then you can follow my Step: 1. Download firmware with correct Product Code by Navifirm Plus, save file in Product Path folder, rename it to RM-1030 2. Check your Product Code here, if your product code shows it V1, then follow these step 3, if not, then download emmc file v2 3. If your device V1, download this file, for repair via Emmc Tool 4. Follow this for add file repair via emmc tool, after select your repair file, you will see the Test Point, solder wires correctly 5. Just tips, don't use usb way when connect emmc TP, I have problem in connection using this methode, tried solder all wire with VCC n VCCQ solder too.. 6. After correct solder, your device will success repair by EMMC tool, if connection take too long, just close ATF window, n tried again, double check the solder wire too... 7. Affter succes repair via Emmc Tool, then you can flash firmware you download in first step 8. Just tips, make sure your battery charge at least 50%, while you click flash button, hold Vol down + power, then connect via USB.. Hope it can help you, good luck... |
The Following User Says Thank You to madgoeslim For This Useful Post: |
12-06-2014, 15:50 | #4 (permalink) | |
Member: 1594457 Status: Offline Sonork: 100.1646470 Thanks Meter: 145 | Quote:
12-06-2014, 19:50 | #6 (permalink) |
Member: 1853929 Status: Offline Sonork: 1653495 Thanks Meter: 426 | When you have JTAG activation, just update your boot file, via Tab Help, update, n just click "check Updates", you'll see all the file you need, include nokia xl rm-1030 v2 too... When connect using jtag, just tips, make a wire as short as possible... Tried using wire only Or, just make your own rj-45 cable Good luck.. |
12-07-2014, 05:32 | #7 (permalink) | |
Can you please tell me more detail about how to make a connection with rj45 cable?...thank you very much may *** bless. | |
12-08-2014, 15:09 | #8 (permalink) |
Member: 1853929 Status: Offline Sonork: 1653495 Thanks Meter: 426 | Try using EMMC TP, like I said in 2# post.. Download all required files, n follow my Pict... 1. Open EMMC Tool, click write, n select Full Boot file, then you'll see where to solder wire 2. After solder TP, connect adapter to rjp45in, then repairing will automatic running 3. Now, disconnect devices, assembly n flash it Flashing firmware N... All Done Good Luck.... |
12-08-2014, 16:46 | #9 (permalink) | |
06-03-2015, 18:19 | #11 (permalink) |
No Life Poster Join Date: Nov 2011 Location: Student
Member: 1686564 Status: Offline Sonork: PM me Thanks Meter: 157 | I Face same proplam My phone Is V2 Not connacted By JTAG Pinout I also Nead Emmc ic pin out Nokia XL RM-1030 CODE- 059W181 THIS IS V2 Phone |
09-27-2015, 16:47 | #12 (permalink) | |
Member: 1853929 Status: Offline Sonork: 1653495 Thanks Meter: 426 | Quote:
09-28-2015, 15:04 | #13 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
http://forum.gsmhosting.com/vbb/f609...925-a-1830880/ Then follow this: http://forum.gsmhosting.com/vbb/10399850-post2.html BR | |
