12-04-2013, 06:08 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Nokia 107 flash file - http://forum.gsmhosting.com/vbb/9827536-post3.html Any one can make it if have ATF box in hand Nokia 106 flash file also not available Br - srinibas |
12-04-2013, 06:11 | #4 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Quote:
12-04-2013, 06:32 | #5 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | |
The Following User Says Thank You to srinibas For This Useful Post: |
12-05-2013, 07:42 | #8 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Hotline4all You can try to read Flash File from another 105 phone using ATF 10.50. To get ATF 10.50, you need to 1. Goto "Product Support" ---> "Update Files" ----> then click a. UPDATE IMPORTANT FILES then click b. Check Software Updates Then, on Infineon "Read Flash" tab, make sure your put a check on "SPI Flash (Nokia 105 / 106)" Then click "Read Flash File" JUST SOME WARNING: NOT ALL Flash File Language Pack can be Read from phone. If it is not possible to Read PPM and CNT correctly, then it will not save the Files at all. B.R. |
12-05-2013, 08:05 | #9 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL For 105 Restarting Problem, or problems when SIM Card is inserted and phone explodes... Just flash MCU SAME VERSION to phone. Read MCU File from another 100% working 105 Phone. B.R. |
12-05-2013, 08:11 | #10 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Georgia Age: 51
Member: 48366 Status: Offline Thanks Meter: 30 | HI, here is the solution for nokia 105, restarting problem when inserting simcard read mcu from working phone, 10.50 atf version, and then flash it to abnormal phone then you will have working phone again here is the log Booting Phone... Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted after 3 attempts... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer ID: 0x00EF Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Multi-Bank / 1.8v Processing Image File: C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-908\rm908_02.700 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 0551 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2232896 bytes Data Checksum: 89F6 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:01:16 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 02.70 22-02-13 RM-908 (c) Nokia IMEI: 358134056xxxxx Product Serial Number: 18E0706BH Product Code : 059R455 Module Code : 0205456 Basic Production Code: 059T2S2 PPM SW Version : V 02.70 22-02-13 RM-908 (c) Nokia MA ADSP Version : p V 02.70\n22-02-13\nRM-908\n(c) NMP\nma MCU SW Version : V 02.70 22-02-13 RM-908 (c) Nokia HW Version : 1000 UEM Version : 1328 UPP Version : 8850 LCD Version : CMI:BEIHAIv01 ILI9163C ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Thanks for the support of X-shadow, keep it up, ATF team *** bless Jham |
12-07-2013, 13:03 | #12 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Almoradi (ALICANTE) . SPAIN
Member: 1677266 Status: Offline Thanks Meter: 90 | hi i have flash dump from brand new phone whit English and frensh lingala and kiswahili. i need spanish ppm plz. RM-908 - Download - 4shared - Euromovil euromovil |
12-10-2013, 11:39 | #14 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: Somewhere
Member: 22466 Status: Offline Thanks Meter: 282 | Quote:
