12-03-2013, 22:40 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Bohicon (Rep of Benin)
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | nokia 105 blink display if put sim - (SOLUTION INSIDE) i don t know, i have one nokia 105 which blink display when i put sim card but without sim card it is ok , but when u try to call 112 , it blink too, i try to hot the network antern but it is the same thing. i try to flash it with atf but not have good flash and when i follow the different discution about it is the bla bla. impossible to poste on good flash. plz help |
The Following User Says Thank You to roni2 For This Useful Post: |
12-03-2013, 22:57 | #2 (permalink) |
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | ATF error in flashing nokia 105 Sending PBL 19456 bytes... PBL Successfully Sent... when i try to flash it whith ATF and nokia_105_rm-908_flash_files it display "Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Spansion Electronics Corp. Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Mirrorbit / Multi-Bank / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-908\rm908_004.350 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00000000~0x0001FFFE ERROR: Erase FIRMWARE Block Failed !!! Flashing ERROR " |
12-04-2013, 04:29 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | It is a hardware fault Where you get the flash file , Flash file not available from officially or from ATF team . Dont try to flash it with fake file , Daily & from very beginning we posting about it . Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
12-04-2013, 05:35 | #4 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Quote:
There is any way to read flash file other working phone by ATF ???? | |
12-05-2013, 07:21 | #6 (permalink) |
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | but now if it hard solution, how succed it , where can i see the hard solution, because like that i thing it is the network solution but how do? thk |
12-05-2013, 07:34 | #7 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @roni2 You can try to read Flash File from another 105 phone using ATF 10.50. To get ATF 10.50, you need to 1. Goto "Product Support" ---> "Update Files" ----> then click a. UPDATE IMPORTANT FILES then click b. Check Software Updates Then, on Infineon "Read Flash" tab, make sure your put a check on "SPI Flash (Nokia 105 / 106)" Then click "Read Flash File" JUST SOME WARNING: NOT ALL Flash File Language Pack can be Read from phone. If it is not possible to Read PPM and CNT correctly, then it will not save the Files at all. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
12-05-2013, 08:04 | #8 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL For 105 Restarting Problem, or problems when SIM Card is inserted and phone explodes... Just flash MCU SAME VERSION to phone. Read MCU File from another 100% working 105 Phone. B.R. |
12-05-2013, 10:18 | #10 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | |
