03-28-2016, 14:59 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: india mumbai
Member: 1847344 Status: Offline Thanks Meter: 300 | nokia 105 bus chek failed and flash failed VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... ERROR: Phone did not Boot !!! Make sure that you plugged the cable to the RJ-45 Port Marked << EXTENSION >> ======================================= || FLASHBUS EXTENSION || || ======= ======= || || | | |\ /| || || | | (O) (O) (O) | CABLE | || || | | |/ \| || || ======= ======= || || || ======================================= ^ ^ ^ | | | | | | PLUG IN CABLE HERE Try booting this phone with "Live Phone" option Check the option beside the "Scan Phone" button Flashing ERROR but scaning ok Try booting this phone with "Live Phone" option Check the option beside the "Scan Phone" button Flashing ERROR MCU: V 03.40 08-08-13 RM-908 (c) Nokia IMEI: 358983054708313 Product Serial Number: D79195FBI Product Code : 059R489 Module Code : 0205457 Basic Production Code: 059T866 PPM SW Version : V 03.40 08-08-13 RM-908 (c) Nokia MG ADSP Version : p+V 03.40\n08-08-13\nRM-908\n(c) NMP\nmg_nlt MCU SW Version : V 03.40 08-08-13 RM-908 (c) Nokia HW Version : 2100 UEM Version : 1328 UPP Version : 8850 LCD Version : CMI:BEIHAIv01 ILI9163C ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED ================================================== ==== Selected VPL File: RM908_059R449_02.70_001.vpl ================================================== ==== Variant Details : NDT MEA FARSI IR [ATF v10.50] Software Version : 02.70 Product Type : RM-908 Product Code : 059R449 |
