Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-17-2014, 09:39   #1 (permalink)
>Amit<'s Avatar
Member: 1359320
Sonork: 100.1620477
Thanks Meter: 79
Plz help atf team strange problem Asha 305
allready flashed same product and write repair pm
asha 305 contact service log :-
Booting Phone via USB...
USB Phone BUSCheck Boot
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Unique Data: 42500811A7032828
Original Product Code: 059Q5G3
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355213051914885\3552130519148 85_15901.rpl
Certificate Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355213051914885\3552130519148 85_CERTIFICATE_12993D55.bin
PM Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355213051914885\3552130519148 85_PMM_PROT_AE148545.bin
Security Code: 12345
Infineon USB Buscheck Done
Phone Restart Mode: TEST MODE
Process Done...
Scanning USB Ports...
Basic Phone Information
MCU Version: V 07.42 07-05-13 RM-766 (c) Nokia
IMEI Plain : 355213051914885
IMEI Spare : A355213051914880
IMEI SV : 33552130519148840F
IMEI (2nd) : 355213051914893
IMEI Spare : A355213051914890
IMEI SV : 33552130519148940F
Phone Model: Nokia 305
Category : Classic Phone
Phone Type : RM-766
Extended Phone Information
Product Serial Number: A48495DAH
Product Code : 059Q5G3
Module Code : 0204884
Basic Production Code: 059K4Q4
Long Production SN : 0
PPM SW Version : V 07.42 07-05-13 RM-766 (c) Nokia MH
BT MCM Version : 19b5-22012
MCU SW Version : V 07.42 07-05-13 RM-766 (c) Nokia
HW Version : 1000
RFIC Version : Dummy RFIC version
LCD Version : TPO
Content Pack Version : Content: mh_059K9H4 V 07.42 07-05-13 RM-766 (c) Nokia
AHNE Version : 11
Bluetooth ID : B0:35:8D:4F:2E:AC
CS Type : GSM900, GSM1800
********** SIMLOCK INFO **********
CONFIG_DATA : 0000000000000000
PROFILE_BITS : 0000000000030000
ASIC : 11
PROVIDER : Unknown Provider
LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
Unable to read SP Data..
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SIMLOCK_TEST : FAILED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : 115B6002
DCC Ver: 004020
Status : OK
Selected VPL File:
RM766_059P553_07.42_049.vpl
Variant Details : RM-766 VAR INDIA-MH IN CV DGREY
Software Version : 07.42
Product Type : RM-766
Product Code : 059P553
Variant Version : 049
Selected VPL File:
RM766_059Q5G3_07.42_016.vpl
Variant Details : RM-766 VAR INDIA-MH IN CV SWHITE
Variant Version : 016
Old 04-17-2014, 10:45   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
@>Amit<
What was the problem in phone that you flashed it? If it was already in Contact Service problem, and you don't have proper backup, then only Nokia RPL will solve this problem.
Old 04-17-2014, 10:55   #3 (permalink)
>Amit<'s Avatar
Member: 1359320
Sonork: 100.1620477
Thanks Meter: 79
the hanset was in contact service costomer ask me that so code is ask in the handset a saw it was restricted code after opening the sim i saw its contact service so i flashed and same and same
Old 04-17-2014, 11:14   #4 (permalink)
Member: 643472
Sonork: 100.96901
If I understand you post correct: It was already in contact service? If so, then return it back to customer, as there is no solution for it except you buy RPL file.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 04-17-2014, 12:47   #5 (permalink)
>Amit<'s Avatar
Member: 1359320
Sonork: 100.1620477
Thanks Meter: 79
thanks for reply me fast ok
Page generated in 0.14477 seconds with 8 queries
