09-23-2015, 06:42 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: China guang dong
Member: 451104 Status: Offline Thanks Meter: 9 | nokia 105 rm-908 can't flash Make sure that you plugged the cable to the RJ-45 Port Marked << EXTENSION >> ======================================= || FLASHBUS EXTENSION || || ======= ======= || || | | |\ /| || || | | (O) (O) (O) | CABLE | || || | | |/ \| || || ======= ======= || || || ======================================= ^ ^ ^ | | | | | | PLUG IN CABLE HERE MCU: V 03.60 11-12-13 RM-908 (c) Nokia IMEI: 351845073963590 Product Serial Number: 8F36ABFAU Product Code : 059R452 Module Code : 0205453 Basic Production Code: 059V9B8 PPM SW Version : V 03.60 11-12-13 RM-908 (c) Nokia IL ADSP Version : p V 03.60\n11-12-13\nRM-908\n(c) NMP\nil MCU SW Version : V 03.60 11-12-13 RM-908 (c) Nokia HW Version : 3000 UEM Version : 1328 UPP Version : 8850 LCD Version : CMI:BEIHAIv01 ILI9163C ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED can't flash VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer ID: 0x00C2 Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Multi-Bank / 1.8v Processing Image File: D:\Program Files\Nokia\Phoenix\Products\RM-908\rm908_003.100 Data Block Found... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... fbus ok why? |
09-23-2015, 07:03 | #3 (permalink) | |
Freak Poster Join Date: Feb 2015 Location: muksudpur
Member: 2345191 Status: Offline Thanks Meter: 35 | nokia 105 rm-908 can't flash Quote:
