Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 07-10-2014, 10:58   #1 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Nokia 106 after SPI tool flash not turn on what wrong ?
Hi I got phone nokia 106 that got polish lang and I read fullflash with fbus cable.
After I remove screen and connect spi cable and want write this full flash to other phone that not have polish lang.
After flash full mean mcu+ppm+cnt or just ppm phone not turn on.
After flash with spi tool backup from phone that I do before write full from other phone phone work again what wrong ??
Do I need remove screen from phone that got polish lang and read full with spi tool that this will work or something is not ok in atf software ??
Here are logs from read fullflash by fbus cable from phone with polish lang:
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
START INFINEON BUS CHECK
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer ID: 0x002C
Flash Chip Type: 64 Mbit (4Mb x 16) NOR
Extended Information: Multi-Bank / 1.8v
Reading NOR Flash: 0x00000000~0x00800000
WARNING: Invalid Data at 0x007FF800
Flash Dump Done...
Phone got big lang that can't extract here is log:
INFINEON BUS CHECK DONE
Detected Phone Type: RM-962
MCU File Saved:
C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-962\rm962_02.900
PPM File Saved:
C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-962\rm962_02.90ea
CNT File Saved:
C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-962\rm962_nai02.90ea
VPL File Saved:
C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-962\RM962_059T2F6_02.90_001.vpl
Performing Final File Checks...
ERROR: MCU File is Incomplete!
Deleting MCU File...
ERROR: PPM File is Incomplete!
Deleting PPM File...
CNT File is OK...
Flash Files Dump Success!
log from flash to other phone fullflash by spi tool with polish and after phone not work:
Resetting ATF Box...
Initializing SPI Module...
Setting VCCIO Voltage...
SPI Module Initialized...
Clocks Sent...
Searching for an SPI Device...
SPI Device Found!
Manufacturer ID: 0x2C Micron
Device ID : 0xCB17
Flash Capacity : 8388608 Bytes
Flash 64K Blocks: 128 Blocks
Unique ID : 00002331516505005100462705137D01
Status Register : 0x00
File Selected : 106_full_polski.bin
File Size : 8386560 bytes
Number of 64K Blocks: 127 blocks
Starting SPI Flash Write...
Write Protecting IMEI, PM and Simlocks Area
SPI Write Done!
Verifying Data...
Data Verification Success!
Total Elapsed Time 00:03:56
I try too write only PPM by spi tool but phone end with same mean not power on.
log from flash to phone backup with spi tool:
Clocks Sent...
SPI Device Found!
Device ID : 0xCB17
Unique ID : 00002331516610006800463105132701
Start Reading 128 Blocks...
Read Blocks Done!
File Saved:
C:\AdvanceBox Turbo Flasher\SPI\Recovered\106full_bez_polaka_FULL.bin
Total Elapsed Time 00:00:08
Clocks Sent...
SPI Device Found!
Device ID : 0xCB17
File Selected : 106full_bez_polaka_FULL.bin
File Size : 8388608 bytes
Number of 64K Blocks: 128 blocks
SPI Write Done!
Verifying Data...
Total Elapsed Time 00:03:49
Any help from support team with good advice will be great
Old 07-10-2014, 13:43   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
Hi,
Make 2 Full dumps.
1. Dump of source phone
2. Dump of destination phone
RAR both full dumps and upload it somewhere, then give me link in PM.
I will check your dumps, so I can make solution.
B.R.
Old 07-10-2014, 16:26   #3 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Can I make dump by fbus or need remove screen from phone with polish and read by spi tool ??
Old 07-10-2014, 17:21   #4 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Both file you got on PM.
I waiting for info.
Old 07-11-2014, 13:39   #5 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Dump means by SPI tool
Br - srinibas
Page generated in 0.16061 seconds with 8 queries
