10-01-2014, 18:28 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Hungary, Győr Age: 46
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | nokia 106 spi problem I have a working but little bit water damaged nokia 106 The phone is working, but the alarm not making any sound so i decided to rewrite phone fw. On fbus this is not possible becouse of big langpack size (about 6-7 lang inside) So i want to try over spi, but the phone not connect, i try via direct soldering and also multi-com SPI adapter also not sees the SPI chip. The manufacturer: winbond. Is it possible that this spi chip damages somehow and interface not working any more (due to water damage i think)or are there any other trick to make it working? many thanx for answer.. |
10-02-2014, 14:45 | #5 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | @dazexy It works on ALL Kinds of ATF BOXES ATF BIG Normal PCB ATF BIG Modified PCB ATF Lightning ATF Nitro See here it is connected to my ATF BIG BOX PINOUT USED for Dolphin Clip: If you get connection problems, try this: 1. Make sure your pinout is 100001% correct 2. Disconnect ATF Box from USB Port 3. Reconnect ATF Box to USB Port 4. Click "Scan SPI" Repeat 1 to 4 is better than just repeat clicking "Scan SPI" This is because sometimes SPI chip is not initialized properly, |
10-02-2014, 17:34 | #6 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | i followed you instructions, but no success, but i think my soldering is good and wires are thin and short, because when i connect the (flashbus port) i get this: Manufacturer ID: 0xEF Winbond Device ID : 0x6017 Flash Capacity : 8388608 Bytes Flash 64K Blocks: 128 Blocks Unique ID : Status Register : 0x00 Resetting ATF Box... Initializing SPI Module... Setting VCCIO Voltage... SPI Module Initialized... Clocks Sent... Searching for an SPI Device... SPI Device Found! Manufacturer ID: 0xEF Winbond Device ID : 0x6017 Flash Capacity : 8388608 Bytes Flash 64K Blocks: 128 Blocks Unique ID : Status Register : 0x00 Start Reading 128 Blocks... Read Blocks Done! File Saved: C:\ATF\AdvanceBox Turbo Flasher\SPI\Recovered\tete_FULL.bin Total Elapsed Time 00:00:09 Resetting ATF Box... Initializing SPI Module... Setting VCCIO Voltage... SPI Module Initialized... Clocks Sent... Searching for an SPI Device... SPI Device Not Found! Try to Reconnect ATF Box USB Cable or Try to Change VCCIO Setting or Check your SPI Connections but is extension port there is no any lifesign. Can i test somehow that my extension port is working right? I think my extension port is not working good. Many thanx for helping.. ps. i know that it will work only in extension port. |
10-02-2014, 18:04 | #7 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | seems finally solved... but please check my dump is correct or damaged. Many thanx: https://www.dropbox.com/s/75vr3lnd6m..._FULL.zip?dl=0 dazexy |
10-03-2014, 01:28 | #8 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | @dazexy Hi, It only works on the "FLASHBUS" port, as you can see in my pictures in post #5. It will NOT WORK on "EXTENSION" port at all. Your "Dropbox" Link is giving me 404... But I believe you can always dump the SPI 2 or 3 times to make sure it is really a 100% OK dump. Thanks again for sharing that Infineon 105 Flash File before. I still don't forget your BIG Help to Infineon SPI FBUS Flashing. |
10-03-2014, 06:16 | #9 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | thanks for your words. Here is corrected link I need check this dump for 1 reason only. In my country is realy rare nokia 106 in my "home" language and i need this dump correct becouse. I will recive several 106 to flash them. And not so long time i have this donor Nokia 106. Many thanx for your help! dazexy Last edited by Advance-Box; 10-03-2014 at 08:51. |
10-03-2014, 08:49 | #11 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | Hi Code: Resetting ATF Box... Initializing SPI Module... Setting VCCIO Voltage... SPI Module Initialized... Clocks Sent... Searching for an SPI Device... SPI Device Found! Manufacturer ID: 0x2C Micron Device ID : 0xCB17 Flash Capacity : 8388608 Bytes Flash 64K Blocks: 128 Blocks Unique ID : 00002331501722007600311905138D01 Status Register : 0x00 File Selected : SPI_backup_Nokia_106_RM-962_FULL.bin File Size : 8388608 bytes Number of 64K Blocks: 128 blocks Starting SPI Flash Write... Write Protecting IMEI, PM and Simlocks Area SPI Write Done! Verifying Data... Data Verification Success! Total Elapsed Time 00:02:47 It's 100% OK Flash Dump. B.R. |
