08-28-2012, 06:11 | #1 (permalink) |
Crazy Poster Join Date: Jun 2009 Location: Burewala Age: 34
Member: 1061328 Status: Offline Sonork: 100.1608604 Thanks Meter: 7 | Nokia 110 Flash & Security Code DONE ( plus modified cable ) Number of Image Files: 3 Processing Image File : rm827__03.04.mcusw Processing Image File : rm827__03.04.ppm_m1 Processing Image File : rm827__03.04.image_m1_059N416 AUTO SELECTED DEAD USB FLASHING... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Sections : 04 Current File : rm827__03.04.mcusw Compile Name: rm827__03.04.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 27266440 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 04 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 43E7 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 04 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A82 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 04 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 45C5 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 of 04 FIRMWARE Erase Block: 0x40280000~0x41BBFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 25952256 bytes Data Checksum: DCD4 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Data Verification Successful... Sections : 01 Current File : rm827__03.04.ppm_m1 Compile Name: package_m1.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 4062644 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x41BC0000~0x421BFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4059300 bytes Data Checksum: D696 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Sections : 01 Current File : rm827__03.04.image_m1_059N416 Compile Name: package_m1_059N416.image.fls Image Type : CONTENT Package Data Size : 14945552 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x421C0000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 14942208 bytes Data Checksum: 1382 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:06:48 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 03.04 20-04-12 RM-827 (c) Nokia IMEI Plain : 353257053319405 IMEI Spare : A353257053319400 IMEI SV : 33532570533194002F Phone Model: Nokia 110 Category : Entry Phone Phone Type : RM-827 ================================================ Extended Phone Information ================================================ Product Serial Number: 9C195F0AH Product Code : 059N417 Module Code : 0205081 Basic Production Code: 059K3X3 Long Production SN : 0 PPM SW Version : V 03.04 20-04-12 RM-827 (c) Nokia M1 BT MCM Version : 19b5-22012 MCU SW Version : V 03.04 20-04-12 RM-827 (c) Nokia HW Version : 1100 RFIC Version : 68 LCD Version : TPO FWID Version : jV 03.04 20-04-12 RM-827 (c) Nokia V 03.04 20-04-12 RM-827 (c) Nokia M1 059N417 001 Content Pack Version : Content: m1_059N416 V 03.04 20-04-12 RM-827 (c) Nokia Bluetooth ID : D0B:32:A3:1B:46 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 14765 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00CS00000401022F03 DCC Ver: 009009 Status : OK Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK MCU: V 03.04 20-04-12 RM-827 (c) Nokia IMEI: 353257053319405 Model : Nokia 110 Product Serial Number: 9C195F0AH Product Code : 059N417 Module Code : 0205081 Basic Production Code: 059K3X3 Long Production SN : 0 PPM SW Version : V 03.04 20-04-12 RM-827 (c) Nokia M1 BT MCM Version : 19b5-22012 MCU SW Version : V 03.04 20-04-12 RM-827 (c) Nokia HW Version : 1100 RFIC Version : 68 LCD Version : TPO Content Pack Version : Content: m1_059N416 V 03.04 20-04-12 RM-827 (c) Nokia ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 MASTER_CODE : 7433401303 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00CS00000401022F03 DCC Ver: 009009 Status : OK ================================================ Phone Lock / Security Code ================================================ SECURITY_CODE : 12345 Mehar Mobile Last edited by srinibas; 08-28-2012 at 06:52. Reason: Resize |
The Following 2 Users Say Thank You to ..::MeHaR : MoBiLe::.. For This Useful Post: |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
