01-22-2013, 13:41 | #1 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1857250 Status: Offline Thanks Meter: 11 | nokia 110 security test fail. how can i solve it. ================================================== ==== ================================================== ==== USB Phone BUSCheck Boot ================================================== ==== ================================================== ==== 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 12101C19B70A2805 Original Product Code: 059P7V5 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\353258054874901\3532580548749 01_62722.rpl Infineon USB Buscheck Done Phone Restart Mode: TEST MODE Process Done... Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 03.04 20-04-12 RM-827 (c) Nokia IMEI Plain : 353258054874901 IMEI Spare : A353258054874900 IMEI SV : 33532580548749002F IMEI (2nd) : 353258054874919 IMEI Spare : A353258054874910 IMEI SV : 33532580548749102F Phone Model: Nokia 110 Category : Entry Phone Phone Type : RM-827 ================================================ Extended Phone Information ================================================ Product Serial Number: A8AA51BAH Product Code : 059P7V5 Module Code : 0205081 Basic Production Code: 059K3X3 Long Production SN : 0 PPM SW Version : V 03.04 20-04-12 RM-827 (c) Nokia S3 BT MCM Version : 19b5-22012 MCU SW Version : V 03.04 20-04-12 RM-827 (c) Nokia HW Version : 1100 RFIC Version : 68 LCD Version : TPO FWID Version : jV 03.04 20-04-12 RM-827 (c) Nokia V 03.04 20-04-12 RM-827 (c) Nokia S3 059P7V5 001 Content Pack Version : Content: s3_059N2B4 V 03.04 20-04-12 RM-827 (c) Nokia Bluetooth ID : D0B:32:E7:35:8D CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00CS00000401022F03 DCC Ver: 010009 Status : OK Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... |
