02-02-2013, 14:39 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: in your hart Age: 40
Member: 864102 Status: Offline Sonork: 100.1617637 Thanks Meter: 146 | nokia 110 successfully flash by ATF BOX with usb modifide cable. here is usb cable pinout- here is log- Number of Image Files: 3 Processing Image File : rm827__03.04.mcusw Processing Image File : rm827__03.04.ppm_mh1 Processing Image File : rm827__03.04.image_mh1_059N0N5 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 12202408260F1822 Original Product Code: 059P8F5 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\353259058659280\3532590586592 80_65208.rpl Data Sections : 04 Current File : rm827__03.04.mcusw Compile Name: rm827__03.04.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 27266440 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 43E7 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A82 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 45C5 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41BBFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 25952256 bytes Data Checksum: DCD4 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm827__03.04.ppm_mh1 Compile Name: package_mh1.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 3272372 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41BC0000~0x421BFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 3269028 bytes Data Checksum: 76D9 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm827__03.04.image_mh1_059N0N5 Compile Name: package_mh1_059N0N5.image.fls Image Type : CONTENT Package Data Size : 15600912 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x421C0000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 15597568 bytes Data Checksum: C0F4 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:05:01 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 03.04 20-04-12 RM-827 (c) Nokia IMEI Plain : 353259058659280 IMEI Spare : A353259058659280 IMEI SV : 33532590586592802F IMEI (2nd) : 353259058659298 IMEI Spare : A353259058659290 IMEI SV : 33532590586592902F Phone Model: Nokia 110 Category : Entry Phone Phone Type : RM-827 ================================================ Extended Phone Information ================================================ Product Serial Number: 2857F6ABI Product Code : 059P8F5 Module Code : 0205081 Basic Production Code: 059K3X3 Long Production SN : 0 PPM SW Version : V 03.04 20-04-12 RM-827 (c) Nokia MH1 BT MCM Version : 19b5-22012 MCU SW Version : V 03.04 20-04-12 RM-827 (c) Nokia HW Version : 2100 RFIC Version : 68 LCD Version : TPO FWID Version : kV 03.04 20-04-12 RM-827 (c) Nokia V 03.04 20-04-12 RM-827 (c) Nokia MH1 059P8F5 001 Content Pack Version : Content: mh1_059N0N5 V 03.04 20-04-12 RM-827 (c) Nokia Bluetooth ID : A4:E7:31:2B:61:F8 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00CS0000040C21AC67 DCC Ver: 004032 Status : OK ================================================== ==== Selected VPL File: RM827_059N0N5_03.04_017.vpl ================================================== ==== Variant Details : RM-827 INDIA_MH1_BLACK_HINDI_IN Software Version : 03.04 Product Type : RM-827 Product Code : 059N0N5 Variant Version : 017 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Changing Phone Mode... (Wait for 10 seconds) Successfully set to : Normal |
The Following 2 Users Say Thank You to moinuddin111 For This Useful Post: |
02-03-2013, 05:27 | #2 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1857250 Status: Offline Thanks Meter: 11 | nokia 110 security test fail. i have a nokia 110 phone . the phone is security test fail. how can i solve it by atf. if i full flash the problem will be solve? anyone help me please........... |
02-03-2013, 11:44 | #3 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
03-28-2013, 18:23 | #6 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Crimea
Member: 1797426 Status: Offline Thanks Meter: 289 | Hi,scheme of cable is work,but forget ''V-bat'',''GND'',''BSI'' for 1] First enter phone to local mode ''V-bat'',''GND'',''BSI'' 2]do how picture show best regards. |
