06-29-2013, 13:39 | #5 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,590 | Quote:
posted image by a user. You can Reset Code and Scan Phone for this model now, as the flash files are not available for this model from Nokia and might not be available later. BR | |
06-29-2013, 15:02 | #12 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,590 | Hi, which ATF software are you using? Did you select Infineon tab ? Post screen shot if you still cannot see it. BR |
06-29-2013, 15:07 | #13 (permalink) |
Freak Poster Join Date: Mar 2013
Member: 1908388 Status: Offline Thanks Meter: 24 | START INFINEON BUS CHECK 17:49:01 : ************************************************** **** 17:49:01 : 17:49:01 : 17:49:01 : Sending PBL 37888 bytes... 17:49:01 : PBL Successfully Sent... 17:49:01 : Sending SBL 65024 bytes... 17:49:02 : SBL Successfully Sent... 17:49:03 : 17:49:03 : Flash Chip Manufacturer: Spansion Electronics Corp. 17:49:03 : Flash Chip Type: 64 Mbit (4Mb x 16) NOR 17:49:03 : Extended Information: Mirrorbit / Multi-Bank / 1.8v 17:49:03 : 17:49:03 : ************************************************** **** 17:49:03 : INFINEON BUS CHECK DONE 17:49:03 : ************************************************** **** 17:49:03 : 17:49:12 : 17:49:13 : 17:49:13 : ================================================ 17:49:13 : Basic Phone Information 17:49:13 : ================================================ 17:49:16 : 17:49:16 : Make sure you have installed the 17:49:16 : COMPLETE Flash Package for this Phone... 17:49:16 : 17:49:16 : Goto "Settings" --> "Nokia Settings" and verify that 17:49:16 : the Folder where you installed your Flash Files are 17:49:16 : in the "PRODUCT PATH TO SCAN" List... 17:49:33 : ================================================ 17:49:33 : Advance Turbo Flasher Found |
