Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 08-22-2012, 15:33   #1 (permalink)
Member: 353717
Sonork: 1001647526
Thanks Meter: 147
Nokia 112-RM-837 flash done
Number of Image Files: 3
Processing Image File :
rm837__03.26.mcusw
rm837__03.26.ppm_s3
rm837__03.26.image_s3_059P4T4
[]: Found 1 active devices.
[Nokia C2-00 USB Phonet]: Opening Connection
[Nokia C2-00 USB Phonet]: Port opened OK!
SW: V 03.26 27-06-12 RM-837 (c) Nokia
IMEI: 351975051483244
START FULL PM BACKUP
Please Wait...
Reading : PM 0~400... OK!
FULL PM Backup Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\351975051483244\USB_FULL_BACK UP_V 03.26 27-06-12 RM-837 (c) Nokia_351975051483244__114136.pm
Reading Battery Value : 4003 mV
Rebooting Phone...
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Sections : 04
Current File : rm837__03.26.mcusw
Compile Name: rm837__03.26.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 27266440 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 04
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 31B4
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 04
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7A82
Processing Section 03 of 04
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: 7EC4
Processing Section 04 of 04
FIRMWARE Erase Block: 0x40280000~0x41BBFFFE
Start Erasing...
Block Erase Done...
Data Size: 25952256 bytes
Data Checksum: 172E
Data Verification Successful...
Sections : 01
Current File : rm837__03.26.ppm_s3
Compile Name: package_s3.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 4654256 Bytes
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x41BC0000~0x421BFFFE
Start Erasing...
Block Erase Done...
Data Size: 4650912 bytes
Data Checksum: 8F70
PPM Data Blocks uploaded to phone...
Sections : 01
Current File : rm837__03.26.image_s3_059P4T4
Compile Name: package_s3_059P4T4.image.fls
Image Type : CONTENT Package
Data Size : 16256272 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x421C0000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 16252928 bytes
Data Checksum: 1D3D
CONTENT Data Blocks uploaded to phone...
Total Flashing Time (Erase + Flashing) : 00:06:59
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
Basic Phone Information
MCU Version: V 03.26 27-06-12 RM-837 (c) Nokia
IMEI Plain : 351975051483244
IMEI Spare : A351975051483240
IMEI SV : 33519750514832409F
Phone Model: Nokia 112
Category : Entry Phone
Phone Type : RM-837
Extended Phone Information
Product Serial Number: A8CBDE0AH
Product Code : 059P4Q9
Module Code : 0205133
Basic Production Code: 059K3X6
Long Production SN : 0
PPM SW Version : V 03.26 27-06-12 RM-837 (c) Nokia S3
BT MCM Version : 19b5-22012
MCU SW Version : V 03.26 27-06-12 RM-837 (c) Nokia
HW Version : 1000
RFIC Version : 68
LCD Version : TPO
FWID Version : jV 03.26 27-06-12 RM-837 (c) Nokia V 03.26 27-06-12 RM-837 (c) Nokia S3 059P4Q9 001
Content Pack Version : Content: s3_059P4T4 V 03.26 27-06-12 RM-837 (c) Nokia
Bluetooth ID : F8:5F:2A:1C:4B6
CS Type : GSM900, GSM1800
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 800000000004000B
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : NI00CS00000401022F03
DCC Ver: 010009
Status : OK
Selected VPL File:
RM837_059P4T4_03.26_001.vpl
Variant Details : RM-837 APAC_S3_RED_STROKE_VN
Software Version : 03.26
Product Type : RM-837
Product Code : 059P4T4
Variant Version : 001
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
Life timer data is not yet used...
Life timer: ----:--
Old 12-30-2012, 12:59   #2 (permalink)
Member: 1567957
Thanks Meter: 16
success flash nokia 112 with usb cable by atf..........
Uploaded with ImageShack.us[/IMG]
rm837__03.32.mcusw
rm837__03.32.ppm_mh1
rm837__03.32.image_mh1_059P3D7
2. Insert USB.
Sending PBL...
Sending SBL...
Unique Data: 12300C0AB00E2803
Original Product Code: 059P3D7
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\353684053708040\3536840537080 40_45641.rpl
Data Sections : 04
Current File : rm837__03.32.mcusw
Compile Name: rm837__03.32.mcusw_ebl_psi.fls
Start Erasing...
Block Erase Done...
Data Checksum: 31B4
Start Erasing...
Block Erase Done...
Data Checksum: 7A82
Start Erasing...
Block Erase Done...
Data Checksum: 8FF0
Start Erasing...
Block Erase Done...
Data Checksum: C8B1
Processing Section 05
FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
Start Erasing...
Block Erase Done...
Data Sections : 01
Current File : rm837__03.32.ppm_mh1
Compile Name: package_mh1.ppm_ebl_psi.fls
Data Size : 3180056 Bytes
Start Erasing...
Block Erase Done...
Data Size: 3176712 bytes
Data Checksum: BD63
Data Sections : 01
Current File : rm837__03.32.image_mh1_059P3D7
Compile Name: package_mh1_059P3D7.image.fls
Data Size : 17304848 Bytes
Start Erasing...
Block Erase Done...
Data Size: 17301504 bytes
Data Checksum: 81FF
CONTENT Erase Block: 0x43E60000~0x43F3FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:07:40
MCU Version: V 03.32 25-09-12 RM-837 (c) Nokia
IMEI Plain : 353684053708040
IMEI Spare : A353684053708040
IMEI SV : 33536840537080415F
IMEI (2nd) : 353684053708057
IMEI Spare : A353684053708050
IMEI SV : 33536840537080515F
Phone Type : RM-837
Product Serial Number: 46E1BDCBI
Product Code : 059P3D7
Module Code : 0205393
Basic Production Code: 059Q0B4
PPM SW Version : V 03.32 25-09-12 RM-837 (c) Nokia MH1
MCU SW Version : V 03.32 25-09-12 RM-837 (c) Nokia
HW Version : 2200
RFIC Version : 68
LCD Version : TPO
FWID Version : kV 03.32 25-09-12 RM-837 (c) Nokia V 03.32 25-09-12 RM-837 (c) Nokia MH1 059P3D7 001
Content Pack Version : Content: mh1_059P3D7 V 03.32 25-09-12 RM-837 (c) Nokia
Bluetooth ID : DC:9F:A4:0D:39:F9
ASIC : 11
LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
PHONE_MODE : TEST
DCC Ver: 010009
Status : OK
Selected VPL File:
RM837_059P3D7_03.32_024.vpl
Variant Details : RM-837 INDIA_MH1_RED_LATIN_IN
Software Version : 03.32
Variant Version : 024
OK
OK
OK
OK
OK
OK
RESET LIFE TIMER TO : 0000:00
OK
Old 09-06-2014, 12:07   #3 (permalink)
Member: 833456
Thanks Meter: 4
my problem is nokia 112 key guard security lock..i flashed this phone by bb5 best dongle and ufs3..bt phone is dead...plz healp any one.....
Old 02-02-2015, 19:34   #4 (permalink)
Crazy Poster
Member: 2043919
Thanks Meter: 19
please help me
i have nokia 112
when i want to flash it with atf box
its stuck on 77%
and doesn't finish
Old 06-26-2015, 08:15   #5 (permalink)
bijoychowdry's Avatar
Member: 1984655
Sonork: 119.30.39.25
Thanks Meter: 81
nokia 112 pbl not found by atf
Old 06-28-2015, 14:39   #6 (permalink)
Member: 1689735
Sonork: chinnacnr
Thanks Meter: 32
please help me my nokia 112 (RM-837) first onset connecting for flash after dead please solution give me next set not on please
Page generated in 0.23342 seconds with 9 queries
