Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 02-25-2011, 13:28   #1 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 538
Nokia 1280 flash done but not power on with battery
hi
nokia 1280 was dead i flash it then set power on with box but not power on with bettry or power supplay
VBATT OFF...
VBATT ON
Setting VBATT Done!...
Booting Phone...
VBATT OFF...
VBATT ON
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted after 2 attempts...
TIME STARTS HERE
Sending PBL 37888 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
VBATT OFF...
VBATT ON
Booting Phone...
VBATT OFF...
VBATT ON
Booting Phone...
Phone Booted after 4 attempts...
TIME STARTS HERE
SBL Successfully Sent...
Flash Chip Manufacturer: STMicroelectronics
Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm647_005.800
FIRMWARE Image Found...
Number of Sections: 03
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 03
FIRMWARE Erase Block: 0x00800000~0x00A0FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 2162688 bytes
Data Checksum: E9B6
Uploading Data Blocks to phone...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 03
FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE
Start Erasing...
Block Erase Done...
Data Size: 2015936 bytes
Data Checksum: B1D2
Processing Section 03 of 03
FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm647_005.80ei
PPM Image Found...
Number of Sections: 01
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x00210000~0x00335CBE
Start Erasing...
Block Erase Done...
Data Size: 1203392 bytes
Data Checksum: 1847
PPM Data Blocks uploaded to phone...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm6470_nai05.80ei
CONTENT Image Found...
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x00EB0000~0x00F04D7E
Start Erasing...
Block Erase Done...
Data Size: 347520 bytes
Data Checksum: 830D
CONTENT Data Blocks uploaded to phone...
Exit Flash Mode Done...
Time Elapse : 00:03:09
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
MCU: V 05.80 06-08-10 RM-647 (c) Nokia
IMEI: 356244042474332
Mastercode : 4724424232
Product Serial Number: HIO045871
Product Code : 0592303
Module Code : 0204496
Basic Production Code: 059C7H2
MCU SW Version : V 05.80 06-08-10 RM-647 (c) Nokia EI
ADSP Version : p V 05.80\n06-08-10\nRM-647\n(c) NMP\nei
PPM Version : V 05.80 06-08-10 RM-647 (c) Nokia
HW Version : 1001
UEM Version : 1328
UPP Version : 8850
LCD Version : INLX:SERIv91 NT7542
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 0000000000030002
Asic : 11
Provider : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST : PASSED
FACTORY SET TO : Factory Set Full
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Production Tune
OK
FACTORY SET TO : Production Tuning
OK
FACTORY SET TO : Reset User Code
OK
FACTORY SET TO : Service Centre
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : User Data
OK
Old 02-25-2011, 13:42   #2 (permalink)
Member: 973412
Thanks Meter: 112
bro hw problem check bsi point
Old 02-27-2012, 05:11   #3 (permalink)
mdmosheur's Avatar
Member: 696206
Sonork: 100.1597401
Thanks Meter: 244
Originally Posted by zeerik View Post
hi
VBATT OFF...
VBATT ON
Booting Phone...
VBATT OFF...
VBATT ON
Booting Phone...
TIME STARTS HERE
VBATT OFF...
VBATT ON
Booting Phone...
VBATT OFF...
VBATT ON
Booting Phone...
TIME STARTS HERE
Start Erasing...
Block Erase Done...
Data Checksum: E9B6
Start Erasing...
Block Erase Done...
Data Checksum: B1D2
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
PPM Image Found...
Start Erasing...
Block Erase Done...
Data Checksum: 1847
Start Erasing...
Block Erase Done...
Data Checksum: 830D
5, 4, 3, 2, 1...
HW Version : 1001
UEM Version : 1328
UPP Version : 8850
Asic : 11
OK
OK
OK
OK
OK
OK
OK
OK
your lcd problam replas lcd or check lcd ways
Thanks
Old 02-27-2012, 07:06   #4 (permalink)
Member: 1001290
Thanks Meter: 78
Thanks
i have same pro. change lcd rehot flash but no found result
Old 02-27-2012, 08:17   #5 (permalink)
Azam Pathan's Avatar
Member: 840953
Sonork: 100.1602229
Thanks Meter: 193
Try this
100% working solution
after flash set not on
and post result
B.R.,
pathanazam
Old 02-27-2012, 11:44   #6 (permalink)
Member: 545722
Sonork: 100.1619680
Thanks Meter: 312
it is problem lsd bro
Old 02-27-2012, 12:48   #7 (permalink)
NOKIA_PLUS's Avatar
Member: 1547481
Thanks Meter: 27
Brother 1st Check Lcd 2nd Check Bsi 100% power on your mobile
Old 05-06-2012, 12:59   #8 (permalink)
sanjeevjha's Avatar
Member: 1270242
Sonork: 1602438
Thanks Meter: 159
Originally Posted by ajuu53 View Post
Try this
and post result
B.R.,
pathanazam
this is a 1200 mobile pcb not 1280
Old 05-06-2012, 14:23   #9 (permalink)
Member: 866650
Sonork: mdsalimkhan_05
Thanks Meter: 134
Try this solution by changing this parts
Old 05-07-2012, 04:13   #10 (permalink)
Member: 1753613
Thanks Meter: 4
do selptest bro & sea logs wher,s failed..i think LCD. or LCD ways problem..
Old 05-07-2012, 10:10   #11 (permalink)
lovepreet's Avatar
Member: 667436
Thanks Meter: 152
bro it may your on/off switch way damage,as in image check if this way is open then make jumper as shown
Old 07-31-2013, 04:46   #12 (permalink)
Member: 1863514
Thanks Meter: 14
First check bsi point then apply jumper
Old 07-31-2013, 05:31   #13 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 116
experience the same problem but after service and heating it work
Old 07-31-2013, 12:04   #14 (permalink)
.::GSM-SHOHAG::.'s Avatar
Member: 1674153
Sonork: 100.1607823
Thanks Meter: 178
hi
VBATT OFF...
VBATT ON
Booting Phone...
VBATT OFF...
VBATT ON
Booting Phone...
TIME STARTS HERE
VBATT OFF...
VBATT ON
Booting Phone...
VBATT OFF...
VBATT ON
Booting Phone...
TIME STARTS HERE
Start Erasing...
Block Erase Done...
Data Checksum: E9B6
Start Erasing...
Block Erase Done...
Data Checksum: B1D2
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
PPM Image Found...
Start Erasing...
Block Erase Done...
Data Checksum: 1847
Start Erasing...
Block Erase Done...
Data Checksum: 830D
5, 4, 3, 2, 1...
HW Version : 1001
UEM Version : 1328
UPP Version : 8850
Asic : 11
OK
OK
OK
OK
OK
OK
OK
OK
Lcd ok
this solution 100% working
.::GSM-SHOHAG::.
The Following User Says Thank You to .::GSM-SHOHAG::. For This Useful Post:
Old 08-01-2013, 06:04   #15 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,196
This is not a hardware discuss section
Time to close the thread
Br - srinibas
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.47927 seconds with 8 queries
