nokia 1280 show unable to read simlock info when i try to flash nokia 1280 with atf it show- VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm647_006.200 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 0E71 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2020800 bytes Data Checksum: 0C57 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm647_006.20mg PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x0036647E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1401984 bytes Data Checksum: CF6A Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm6470_nai06.20mg CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00EB0000~0x00F0C6BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 378560 bytes Data Checksum: C1B9 Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:01:51 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 06.20 01-12-10 RM-647 (c) Nokia IMEI: V 06.20 01-12-10 RM-647 (c) Nokia Model : A 351524049596079 Product Code : 1170AEDAI Module Code : 0592282 Basic Production Code: 0204426 Flash Code : 0589577 BT MCM Version : V 06.20 01-12-10 RM-647 (c) Nokia MG AEM Version : p V 06.20\n01-12-10\nRM-647\n(c) NMP\nmg HW Version : V 06.20 01-12-10 RM-647 (c) Nokia PCI Version : 3000 UPP Version : 1328 RFIC Version : 8850 Camera : WIN:SERI:90 NT7542 ********** SIMLOCK INFO ********** ERROR : Unable to read Simlock Info ... Maybe you are reading BB5 phone ... ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK is this set is repairlble with advance turbo flasher ? |
Not supported yet BR> |
