nokia 1616-2c when i try to unlock nokia 1616-2c it still say it lock same way y is that |
you need to post logs so we can help. There are 2 kinds of 1616... one is DCT4 and another is Infineon... I think your 1616 is Infineon... check back sticker.. If it say RH-129, then it is DCT4 and can be unlocked with 1 CLICK RSA Unlock... If it say RH-125, then it is Infineon and it cannot be unlocked with 1 CLICK RSA Unlock... you need to BF this phone, and ATF Does not support Infineon BF for now |
[QUOTE=Advance-Box;8368954]you need to post logs so we can help.[/Q i scan the phone for info as u can see in the screenshot but when i click unlock it say the same thing |
[QUOTE=Advance-Box;8368954]you need to post logs so we can help.[/Q i scan the phone for info as u can see in the screenshot but when i click unlock it say the same thing look at logs 12:31:58 : VBATT Powering Down <<<< 12:32:02 : VBATT Powering Up >>>> 12:32:02 : SET VCCIO Level Done 12:32:02 : SET BSI Load Done 12:32:02 : 12:32:06 : MCU: V 06.18 05-13-11 RH-129 (c) Nokia 12:32:06 : IMEI: 012569006898290 12:32:06 : Product Serial Number: 358C349AH 12:32:06 : Product Code : 059D5W0 12:32:06 : Module Code : 0204789 12:32:06 : Basic Production Code: 059G6X1 12:32:07 : PPM SW Version : V 06.18 05-13-11 RH-129 (c) Nokia UB 12:32:07 : ADSP Version : p V 06.18\n05-13-11\nRH-129\n(c) NMP\nub 12:32:07 : MCU SW Version : V 06.18 05-13-11 RH-129 (c) Nokia 12:32:07 : HW Version : 0105 12:32:07 : UEM Version : 1328 12:32:07 : UPP Version : 8850 12:32:07 : LCD Version : TPO:BOHAIv80 HX5081 12:32:08 : ********** SIMLOCK INFO ********** 12:32:08 : CONFIG_DATA : 3102000000000000 12:32:08 : PROFILE_BITS : 800000000003000B 12:32:08 : ASIC : 11 12:32:08 : PROVIDER : Union Telephone Company ;United States [GSM] 12:32:08 : 12:32:09 : Block [1] 1:Close 12:32:09 : Block [2] 1:Close 12:32:09 : Block [3] 1:Close 12:32:09 : Block [4] 1:Close 12:32:09 : Block [5] 1:Close 12:32:09 : Block [6] 1:Close 12:32:09 : Block [7] 1:Close 12:32:09 : Block [8] 1:Close 12:32:09 : Block [9] 1:Close 12:32:09 : Block [10] 1:Close 12:32:09 : Block [11] 1:Close 12:32:09 : Block [12] 1:Close 12:32:09 : Block [13] 1:Close 12:32:09 : Block [14] 1:Close 12:32:09 : ST_SIMLOCK_TEST : PASSED 12:32:09 : ST_LCD_TEST : PASSED 12:32:09 : SECURITY_CODE : ÿ 12:32:09 : MASTER_CODE : 0704153265 12:32:09 : PHONE_MODE : LOCAL 12:32:09 : 12:32:09 : 12:32:09 : 12:32:09 : ================================================== ==== 12:32:09 : Selected VPL File: 12:32:09 : RH129_059D5W0_06.18_002.vpl 12:32:09 : ================================================== ==== 12:32:09 : Variant Details : RH-129 1616 AMER-UB T-MOBILE PP CL GY 12:32:09 : Software Version : 06.18 12:32:09 : Product Type : RH-129 12:32:09 : Product Code : 059D5W0 12:32:09 : Variant Version : 002 12:32:09 : 12:32:15 : 12:32:15 : FACTORY SET TO : Full Factory Set 12:32:16 : OK 12:32:16 : FACTORY SET TO : User Data 12:32:16 : OK 12:32:16 : FACTORY SET TO : Leave Factory 12:32:16 : OK 12:32:16 : FACTORY SET TO : Service Center 12:32:16 : OK 12:32:16 : FACTORY SET TO : Software Upgrade 12:32:16 : OK 12:32:16 : FACTORY SET TO : Production Tune 12:32:16 : OK 12:32:22 : MCU: V 06.18 05-13-11 RH-129 (c) Nokia 12:32:22 : IMEI: 012569006898290 12:32:23 : Product Serial Number: 358C349AH 12:32:23 : Product Code : 059D5W0 12:32:23 : Module Code : 0204789 12:32:23 : Basic Production Code: 059G6X1 12:32:23 : PPM SW Version : V 06.18 05-13-11 RH-129 (c) Nokia UB 12:32:23 : ADSP Version : p V 06.18\n05-13-11\nRH-129\n(c) NMP\nub 12:32:23 : MCU SW Version : V 06.18 05-13-11 RH-129 (c) Nokia 12:32:23 : HW Version : 0105 12:32:23 : UEM Version : 1328 12:32:23 : UPP Version : 8850 12:32:24 : LCD Version : TPO:BOHAIv80 HX5081 12:32:24 : ********** SIMLOCK INFO ********** 12:32:24 : CONFIG_DATA : 3102000000000000 12:32:24 : PROFILE_BITS : 800000000003000B 12:32:24 : ASIC : 11 12:32:24 : PROVIDER : Union Telephone Company ;United States [GSM] 12:32:24 : 12:32:25 : Block [1] 1:Close 12:32:25 : Block [2] 1:Close 12:32:25 : Block [3] 1:Close 12:32:25 : Block [4] 1:Close 12:32:25 : Block [5] 1:Close 12:32:25 : Block [6] 1:Close 12:32:25 : Block [7] 1:Close 12:32:25 : Block [8] 1:Close 12:32:25 : Block [9] 1:Close 12:32:25 : Block [10] 1:Close 12:32:25 : Block [11] 1:Close 12:32:25 : Block [12] 1:Close 12:32:25 : Block [13] 1:Close 12:32:25 : Block [14] 1:Close 12:32:25 : ST_SIMLOCK_TEST : PASSED 12:32:25 : ST_LCD_TEST : PASSED 12:32:25 : SECURITY_CODE : ÿ 12:32:25 : MASTER_CODE : 0704153265 12:32:25 : PHONE_MODE : LOCAL 12:32:25 : 12:32:25 : 12:32:26 : 12:32:28 : MCU: V 06.18 05-13-11 RH-129 (c) Nokia 12:32:28 : IMEI: 012569006898290 12:32:28 : Product Serial Number: 358C349AH 12:32:28 : Product Code : 059D5W0 12:32:28 : Module Code : 0204789 12:32:28 : Basic Production Code: 059G6X1 12:32:28 : PPM SW Version : V 06.18 05-13-11 RH-129 (c) Nokia UB 12:32:28 : ADSP Version : p V 06.18\n05-13-11\nRH-129\n(c) NMP\nub 12:32:29 : MCU SW Version : V 06.18 05-13-11 RH-129 (c) Nokia 12:32:29 : HW Version : 0105 12:32:29 : UEM Version : 1328 12:32:29 : UPP Version : 8850 12:32:29 : LCD Version : TPO:BOHAIv80 HX5081 12:32:30 : ********** SIMLOCK INFO ********** 12:32:30 : CONFIG_DATA : 3102000000000000 12:32:30 : PROFILE_BITS : 800000000003000B 12:32:30 : ASIC : 11 12:32:30 : PROVIDER : Union Telephone Company ;United States [GSM] 12:32:30 : 12:32:30 : Block [1] 1:Close 12:32:30 : Block [2] 1:Close 12:32:30 : Block [3] 1:Close 12:32:30 : Block [4] 1:Close 12:32:30 : Block [5] 1:Close 12:32:30 : Block [6] 1:Close 12:32:30 : Block [7] 1:Close 12:32:30 : Block [8] 1:Close 12:32:30 : Block [9] 1:Close 12:32:30 : Block [10] 1:Close 12:32:30 : Block [11] 1:Close 12:32:30 : Block [12] 1:Close 12:32:30 : Block [13] 1:Close 12:32:30 : Block [14] 1:Close 12:32:30 : ST_SIMLOCK_TEST : PASSED 12:32:30 : ST_LCD_TEST : PASSED 12:32:30 : SECURITY_CODE : ÿ 12:32:30 : MASTER_CODE : 0704153265 12:32:31 : PHONE_MODE : LOCAL |
Hi, This one phone is Infineon. BR |
Sir please let me know when will unlocking release for 1616 Mexican telcel thank you in Advance |
