Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 04-30-2012, 18:37   #1 (permalink)
headszone1's Avatar
Member: 1568769
Sonork: 161.1167
Thanks Meter: 168
nokia 1616-2c
when i try to unlock nokia 1616-2c it still say it lock same way y is that
The Following User Says Thank You to headszone1 For This Useful Post:
Old 04-30-2012, 18:44   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,040
you need to post logs so we can help.
There are 2 kinds of 1616... one is DCT4 and another is Infineon...
I think your 1616 is Infineon...
check back sticker..
If it say RH-129, then it is DCT4 and can be unlocked with 1 CLICK RSA Unlock...
If it say RH-125, then it is Infineon and it cannot be unlocked with 1 CLICK RSA Unlock...
you need to BF this phone, and ATF Does not support Infineon BF for now
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 04-30-2012, 18:50   #3 (permalink)
headszone1's Avatar
Member: 1568769
Sonork: 161.1167
Thanks Meter: 168
[QUOTE=Advance-Box;8368954]you need to post logs so we can help.[/Q
i scan the phone for info as u can see in the screenshot but when i click unlock it say the same thing
Old 04-30-2012, 18:56   #4 (permalink)
headszone1's Avatar
Member: 1568769
Sonork: 161.1167
Thanks Meter: 168
i scan the phone for info as u can see in the screenshot but when i click unlock it say the same thing look at logs
12:31:58 : VBATT Powering Down <<<<
12:32:02 : VBATT Powering Up >>>>
12:32:02 : SET VCCIO Level Done
12:32:02 : SET BSI Load Done
12:32:02 :
12:32:06 : MCU: V 06.18 05-13-11 RH-129 (c) Nokia
12:32:06 : IMEI: 012569006898290
12:32:06 : Product Serial Number: 358C349AH
12:32:06 : Product Code : 059D5W0
12:32:06 : Module Code : 0204789
12:32:06 : Basic Production Code: 059G6X1
12:32:07 : PPM SW Version : V 06.18 05-13-11 RH-129 (c) Nokia UB
12:32:07 : ADSP Version : p V 06.18\n05-13-11\nRH-129\n(c) NMP\nub
12:32:07 : MCU SW Version : V 06.18 05-13-11 RH-129 (c) Nokia
12:32:07 : HW Version : 0105
12:32:07 : UEM Version : 1328
12:32:07 : UPP Version : 8850
12:32:07 : LCD Version : TPO:BOHAIv80 HX5081
12:32:08 : ********** SIMLOCK INFO **********
12:32:08 : CONFIG_DATA : 3102000000000000
12:32:08 : PROFILE_BITS : 800000000003000B
12:32:08 : ASIC : 11
12:32:08 : PROVIDER : Union Telephone Company ;United States [GSM]
12:32:08 :
12:32:09 : Block [1] 1:Close
12:32:09 : Block [2] 1:Close
12:32:09 : Block [3] 1:Close
12:32:09 : Block [4] 1:Close
12:32:09 : Block [5] 1:Close
12:32:09 : Block [6] 1:Close
12:32:09 : Block [7] 1:Close
12:32:09 : Block [8] 1:Close
12:32:09 : Block [9] 1:Close
12:32:09 : Block [10] 1:Close
12:32:09 : Block [11] 1:Close
12:32:09 : Block [12] 1:Close
12:32:09 : Block [13] 1:Close
12:32:09 : Block [14] 1:Close
12:32:09 : ST_SIMLOCK_TEST : PASSED
12:32:09 : ST_LCD_TEST : PASSED
12:32:09 : SECURITY_CODE :
12:32:09 : MASTER_CODE : 0704153265
12:32:09 : PHONE_MODE : LOCAL
12:32:09 :
12:32:09 :
12:32:09 :
12:32:09 : ================================================== ====
12:32:09 : Selected VPL File:
12:32:09 : RH129_059D5W0_06.18_002.vpl
12:32:09 : Variant Details : RH-129 1616 AMER-UB T-MOBILE PP CL GY
12:32:09 : Software Version : 06.18
12:32:09 : Product Type : RH-129
12:32:09 : Product Code : 059D5W0
12:32:09 : Variant Version : 002
12:32:09 :
12:32:15 :
12:32:15 : FACTORY SET TO : Full Factory Set
12:32:16 : OK
12:32:16 : FACTORY SET TO : User Data
12:32:16 : OK
12:32:16 : FACTORY SET TO : Leave Factory
12:32:16 : OK
12:32:16 : FACTORY SET TO : Service Center
12:32:16 : OK
12:32:16 : FACTORY SET TO : Software Upgrade
12:32:16 : OK
12:32:16 : FACTORY SET TO : Production Tune
12:32:16 : OK
12:32:22 : MCU: V 06.18 05-13-11 RH-129 (c) Nokia
12:32:22 : IMEI: 012569006898290
12:32:23 : Product Serial Number: 358C349AH
12:32:23 : Product Code : 059D5W0
12:32:23 : Module Code : 0204789
12:32:23 : Basic Production Code: 059G6X1
12:32:23 : PPM SW Version : V 06.18 05-13-11 RH-129 (c) Nokia UB
12:32:23 : ADSP Version : p V 06.18\n05-13-11\nRH-129\n(c) NMP\nub
12:32:23 : MCU SW Version : V 06.18 05-13-11 RH-129 (c) Nokia
12:32:23 : HW Version : 0105
12:32:23 : UEM Version : 1328
12:32:23 : UPP Version : 8850
12:32:24 : LCD Version : TPO:BOHAIv80 HX5081
12:32:24 : ********** SIMLOCK INFO **********
12:32:24 : CONFIG_DATA : 3102000000000000
12:32:24 : PROFILE_BITS : 800000000003000B
12:32:24 : ASIC : 11
12:32:24 : PROVIDER : Union Telephone Company ;United States [GSM]
12:32:24 :
12:32:25 : Block [1] 1:Close
12:32:25 : Block [2] 1:Close
12:32:25 : Block [3] 1:Close
12:32:25 : Block [4] 1:Close
12:32:25 : Block [5] 1:Close
12:32:25 : Block [6] 1:Close
12:32:25 : Block [7] 1:Close
12:32:25 : Block [8] 1:Close
12:32:25 : Block [9] 1:Close
12:32:25 : Block [10] 1:Close
12:32:25 : Block [11] 1:Close
12:32:25 : Block [12] 1:Close
12:32:25 : Block [13] 1:Close
12:32:25 : Block [14] 1:Close
12:32:25 : ST_SIMLOCK_TEST : PASSED
12:32:25 : ST_LCD_TEST : PASSED
12:32:25 : SECURITY_CODE :
12:32:25 : MASTER_CODE : 0704153265
12:32:25 : PHONE_MODE : LOCAL
12:32:25 :
12:32:25 :
12:32:26 :
12:32:28 : MCU: V 06.18 05-13-11 RH-129 (c) Nokia
12:32:28 : IMEI: 012569006898290
12:32:28 : Product Serial Number: 358C349AH
12:32:28 : Product Code : 059D5W0
12:32:28 : Module Code : 0204789
12:32:28 : Basic Production Code: 059G6X1
12:32:28 : PPM SW Version : V 06.18 05-13-11 RH-129 (c) Nokia UB
12:32:28 : ADSP Version : p V 06.18\n05-13-11\nRH-129\n(c) NMP\nub
12:32:29 : MCU SW Version : V 06.18 05-13-11 RH-129 (c) Nokia
12:32:29 : HW Version : 0105
12:32:29 : UEM Version : 1328
12:32:29 : UPP Version : 8850
12:32:29 : LCD Version : TPO:BOHAIv80 HX5081
12:32:30 : ********** SIMLOCK INFO **********
12:32:30 : CONFIG_DATA : 3102000000000000
12:32:30 : PROFILE_BITS : 800000000003000B
12:32:30 : ASIC : 11
12:32:30 : PROVIDER : Union Telephone Company ;United States [GSM]
12:32:30 :
12:32:30 : Block [1] 1:Close
12:32:30 : Block [2] 1:Close
12:32:30 : Block [3] 1:Close
12:32:30 : Block [4] 1:Close
12:32:30 : Block [5] 1:Close
12:32:30 : Block [6] 1:Close
12:32:30 : Block [7] 1:Close
12:32:30 : Block [8] 1:Close
12:32:30 : Block [9] 1:Close
12:32:30 : Block [10] 1:Close
12:32:30 : Block [11] 1:Close
12:32:30 : Block [12] 1:Close
12:32:30 : Block [13] 1:Close
12:32:30 : Block [14] 1:Close
12:32:30 : ST_SIMLOCK_TEST : PASSED
12:32:30 : ST_LCD_TEST : PASSED
12:32:30 : SECURITY_CODE :
12:32:30 : MASTER_CODE : 0704153265
12:32:31 : PHONE_MODE : LOCAL
Old 05-02-2012, 10:21   #5 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,483
Hi,
This one phone is Infineon.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 05-16-2012, 12:20   #6 (permalink)
Member: 1061082
Thanks Meter: 4
Sir please let me know when will unlocking release for 1616 Mexican telcel thank you in Advance
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.31306 seconds with 8 queries
