GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Advance-Box (https://forum.gsmhosting.com/vbb/f609/)
-   -   nokia 1616 all ok but set dead (https://forum.gsmhosting.com/vbb/f609/nokia-1616-all-ok-but-set-dead-1209317/)
nilan 02-17-2011 09:50
after flash set not power on
VBATT OFF...
VBATT ON
Setting VBATT Done!...
Booting Phone...
VBATT OFF...
VBATT ON
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted after 2 attempts...
TIME STARTS HERE
Sending PBL 37888 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: STMicroelectronics
Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-125\rh125_006.200
FIRMWARE Image Found...
Number of Sections: 03
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 03
FIRMWARE Erase Block: 0x00800000~0x00A0FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 2162688 bytes
Data Checksum: 507C
Uploading Data Blocks to phone...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 03
FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE
Start Erasing...
Block Erase Done...
Data Size: 2136128 bytes
Data Checksum: FD7E
Processing Section 03 of 03
FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-125\rh125_006.20ua
PPM Image Found...
Number of Sections: 01
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x00210000~0x003DC6BE
Start Erasing...
Block Erase Done...
Data Size: 1885888 bytes
Data Checksum: EE20
PPM Data Blocks uploaded to phone...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-125\rh1250_nai06.20ua
CONTENT Image Found...
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x00EB0000~0x00F010BE
Start Erasing...
Block Erase Done...
Data Size: 331968 bytes
Data Checksum: D7E8
CONTENT Data Blocks uploaded to phone...
Exit Flash Mode Done...
Time Elapse : 00:02:55
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
MCU: V 06.20 01-12-10 RH-125 (c) Nokia
IMEI: 355387047746179
Mastercode : 3644060136
Product Serial Number: 53D3229AI
Product Code : 0595840
Module Code : 0204343
Basic Production Code: 059C7B8
MCU SW Version : V 06.20 01-12-10 RH-125 (c) Nokia UA
ADSP Version : p V 06.20\n01-12-10\nRH-125\n(c) NMP\nua
PPM Version : V 06.20 01-12-10 RH-125 (c) Nokia
HW Version : 1010
UEM Version : 1328
UPP Version : 8850
LCD Version : UNKWN: IDs: 00:00:00
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 0000000000030002
Asic : 11
Provider : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST : FAILED
Phone Cannot Enter Normal Mode if LCD
is Damaged or LCD is not Properly
Connected to the Main PCB
FACTORY SET TO : Factory Set Full
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Production Tune
OK
FACTORY SET TO : Production Tuning
OK
FACTORY SET TO : Reset User Code
OK
FACTORY SET TO : Service Centre
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : User Data
OK
Changing Phone Mode... (Wait for 5 seconds)
Successfully set to : Normal
dey mobiles 02-17-2011 12:05
Dear try to change Lcd here u see ur log...........
..::Angel::.. 02-17-2011 14:00
@nilan
As log says, LCD problem in phone, it need to be changed!
coolnic 02-19-2011 14:36
i change the lcd 1616 now also cant open phone now
coolnic 02-19-2011 14:40
i got 1280 and 1616 all set ok.. but
also
coolnic 02-19-2011 14:41
1280 i change LCD the can open .but lcd no screen .jz got light and sound only.
shaikhaltaf_m 02-19-2011 14:43
try with letest file & use good qulity display your problam 1000000000% solve.
mizuliza 02-20-2011 06:49
VBATT OFF...
VBATT ON
Booting Phone...
VBATT OFF...
VBATT ON
Booting Phone...
TIME STARTS HERE
Start Erasing...
Block Erase Done...
Data Checksum: 507C
Start Erasing...
Block Erase Done...
Data Checksum: FD7E
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
PPM Image Found...
Start Erasing...
Block Erase Done...
Data Checksum: EE20
Start Erasing...
Block Erase Done...
Data Checksum: D7E8
5, 4, 3, 2, 1...
HW Version : 1010
UEM Version : 1328
UPP Version : 8850
Asic : 11
OK
OK
OK
OK
OK
OK
OK
OK
Check this :- 1616LCDWAYS.jpg picture by MizuLiza - Photobucket your problem solved 1000000000% .
rekha1255 11-05-2011 11:25
here realy all is well but still set dead
bus chek -
Booting Phone...
Phone Booted after 6 attempts...
START INFINEON BUS CHECK
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
INFINEON BUS CHECK DONE
INFO -
IMEI: 35270xxxxxxxxxx
Product Serial Number: 0D24867AI
Basic Production Code: 059C283
PPM SW Version : V 06.20 01-12-10 RH-125 (c) Nokia MG
ADSP Version : p+V 06.20\n01-12-10\nRH-125\n(c) NMP\nmg_nlt
HW Version : 1000
UEM Version : 1328
UPP Version : 8850
LCD Version : INNO:BOHAIv93 NT39121
ASIC : 11
PROVIDER : Default Test Operator
ST_LCD_TEST : PASSED
BUT Set dead :(
when try to change Normal mode -
ERROR: Selected Mode is NOT APPLICABLE
what will i do for this ??
:rolleyes:
Advance-Box 11-05-2011 11:52
@rekha1255
In Hardware Section, I saw some guy suggested to check the BSI line on the PCB
of the Phone. Some missing resistor which he "jumpered" to another point in
order to power up the phone with Battery.
Gsm-Rocky 11-05-2011 11:58
Originally Posted by rekha1255 (Post 7863491)
bus chek -
Booting Phone...
INFO -
HW Version : 1000
UEM Version : 1328
UPP Version : 8850
ASIC : 11
BUT Set dead :(
:rolleyes:
Bro this hadware And this solution Try ok and post me result
http://img838.imageshack.us/img838/6541/nokia201616.jpg
onelove980 11-05-2011 12:07
change LCD if not ok then find LCD ways
Nadeem Waris 11-05-2011 12:17
VBATT OFF...
VBATT ON
Booting Phone...
VBATT OFF...
VBATT ON
Booting Phone...
TIME STARTS HERE
Start Erasing...
Block Erase Done...
Data Checksum: 507C
Start Erasing...
Block Erase Done...
Data Checksum: FD7E
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
PPM Image Found...
Start Erasing...
Block Erase Done...
Data Checksum: EE20
Start Erasing...
Block Erase Done...
Data Checksum: D7E8
5, 4, 3, 2, 1...
HW Version : 1010
UEM Version : 1328
UPP Version : 8850
Asic : 11
OK
OK
OK
OK
OK
OK
OK
OK
change lcd 100 % work u r set
Nadeem Waris 11-05-2011 12:19
bus chek -
Booting Phone...
INFO -
HW Version : 1000
UEM Version : 1328
UPP Version : 8850
ASIC : 11
BUT Set dead :(
:rolleyes:
http://www.mediafire.com/imgbnc.php/...f1e8568b5g.jpg
cgpatel5800 11-05-2011 12:36
dear disply chnge karo 100% tested
sachin patel
Page generated in 0.24956 seconds with 6 queries
